Description of Small Cabin Off-Grid Solar Power Setup Components
Eliminator Solar Panel, 15 Watt
- Eliminator Solar power panels are an easy-to-use, guaranteed solution to an ever-growing need for alternate power sources or backup power
- Weatherproof panels convert sunlight, even in low light conditions, into 12V electricity - ideal for charging all types of vehicle batteries and power packs
- Large 15W panel can be used to charge power supply systems in larger vehicles, homes and cottages
- Extends battery life, thus reducing expense of replacement. Includes quick-connect hardware: connecting wire, DC clips, 12V socket plug and barrel plug, mounting hardware/accessories
- Built-in reverse current protection - won't deplete the power-supply system
- 5-year warranty
- 38" x 13" x 1" / 97cm x 33cm x 2.5cm
7A Eliminator Charge Controller
- For use with the Battery Saver 15W Solar Charger and larger units
- Regulates up to 105W of solar power
- Worry-free operation
- Reduces system maintenance
- Includes status light indicators
- Installs in minutes
- Max. Load: 105 watts/7 amps
- Dimensions: 3.15" x 1.75" x 1" (80 x 44 x 25 mm)
- Weight: 0.19 lbs. (85 g)
- Operating Temperature Range: 14°F to 104°F / -10°C to 40°C
Motomaster Eliminator 1,200A PowerBox
- Provides 120V AC household power, 12V DC power
- Built-in 1,200W inverter
- Easy-to-monitor, dual-outlet AC panel
- Sealed, 60 amp-hour AGM battery withstands long periods of inactivity with minimal self-discharge
- Recharge PowerBox from a standard wall outlet or from your car, truck, or RV
- Ideal for power emergencies - run essential appliances like refrigerators, cordless/mobile phones, radios, fireplace fans, table lamps, microwaves, etc., when the power goes out
- Operate power drills, belt sanders, circular saws, hedge trimmers, leaf blowers, vacuums, computers, large monitors, fax machines, and inkjet printers
- Run blenders, video games, TVs and VCRs, satellite equipment, coffee makers, portable coolers, and more
- Comes with a rugged cart that can be wheeled from room to room or outdoors over rough terrain
Electrical Appliance Power Consumption
This means that a brand new, fully charged battery can (theoretically) power a 100W light bulb for 8.4 hrs.
Tip:
To ensure maximum battery life, always keep the Power Box in the up-right position!
<< BACK to Previous Page | Small Cabin HOME | BACK to Previous Page >> |
