. 1 . 2 . >> |
# Posted: 7 Sep 2017 10:43pm
You're in a dark room with a candle, a wood stove, and a gas lamp. You only have one match, so what do you light first?
# Posted: 7 Sep 2017 10:48pm - Edited by: ICC
The match. You can't light any of the others without the match
# Posted: 8 Sep 2017 01:05pm
Glad you answered first. I was going to say the candle.
Smawgunner
# Posted: 8 Sep 2017 04:33pm
You're in a room with no windows, doors or other obvious ways out. All you have is a table and a mirror, how do you get out?
# Posted: 8 Sep 2017 06:11pm - Edited by: rockies
Below are nine dots arranged in a set of three rows. Your challenge is to draw four straight lines which go through the middle of all of the dots without taking the pencil off the paper. If you were using a pencil, you must start from any position and draw the lines one after the other without taking your pencil off the page. Each line starts where the last line finishes.
# Posted: 8 Sep 2017 06:49pm
Quoting: Smawgunner You're in a room with no windows, doors or other obvious ways out. All you have is a table and a mirror, how do you get out?
Look in the mirror, then at the wall and back at the mirror to see what you saw. Use the saw to cut the table in half and join the two halves to make a whole. Put the “hole†on the wall and climb out.
Kinda lame.
# Posted: 8 Sep 2017 06:55pm - Edited by: ICC
Quoting: rockies Nine Dots
1-Lower right corner to upper left corner...... 2-Upper left through upper right and beyond far enough to make the next line...... 3-Then from there through the center dot in the right hand column, then straight through the center dot in the lower row, and beyond as before...... 4-then striaght up the left hand column going to the upper left dot again.
# Posted: 8 Sep 2017 10:01pm
There is a lightbulb inside a closet. The door is closed, and you cannot see if the light is on or off through the door. However, you know the light is off to start. Outside of the closet, there are three light switches. One of the switches controls the lightbulb in the closet. You can flip the switches however you want, but once you open the door, you can no longer touch the switches.
How do you figure out without a doubt which switch controls the light?
Smawgunner
# Posted: 8 Sep 2017 11:04pm
Quoting: ICC Look in the mirror, then at the wall and back at the mirror to see what you saw. Use the saw to cut the table in half and join the two halves to make a whole. Put the “hole†on the wall and climb out.
Lol, yeah..kinda lame, couldn't resist.
# Posted: 8 Sep 2017 11:36pm
Quoting: rockies There is a lightbulb inside a closet.
OK. The light is off to begin with. Are we to assume that means all three light switches are off to begin with as well? If I assume that, then first turn on switch 1 and wait a minute or two. Turn off switch 1 and right away turn on switch 2 and open the door.
If the light is on then switch 2 operates the light. If the light is off then carefully feel the bulb. If the bulb is hot or warm then switch 1 controls the light. If the bulb is cold then switch 3 operates the light.
# Posted: 10 Sep 2017 06:11pm
You're living in a cabin where all four exterior walls have southern exposure and a bear walks by. What color is the bear?
# Posted: 10 Sep 2017 08:10pm - Edited by: Just
White . you are at the north pole..
Bushwhacked
# Posted: 11 Sep 2017 03:41am
This is the best thread!
# Posted: 11 Sep 2017 10:06pm
What 8 letter word can have a letter taken away and it still makes a word. Take another letter away and it still makes a word. Keep on doing that until you have one letter left. What is the word?
# Posted: 11 Sep 2017 10:08pm
Two girls were born to the same mother, on the same day, at the same time, in the same month and year and yet they’re not twins. How can this be?
# Posted: 11 Sep 2017 10:09pm
You’re running a race and pass the person in 2nd place. What place are you in now?
# Posted: 11 Sep 2017 11:55pm
How many trucks can a truck stop stop if a truck stop could stop trucks?
# Posted: 12 Sep 2017 12:57am
Quoting: rockies What 8 letter word can have a letter taken away and it still makes a word. Take another letter away and it still makes a word. Keep on doing that until you have one letter left. What is the word?
Keep an open mind.. the letters can be removed from anywhere not just the ends.. Starting Staring String Sting Sing Sin In I
# Posted: 12 Sep 2017 01:00am
Quoting: rockies You’re running a race and pass the person in 2nd place. What place are you in now?
second
# Posted: 12 Sep 2017 10:39am
Quoting: rockies Two girls were born to the same mother, on the same day, at the same time, in the same month and year and yet they’re not twins. How can this be?
They're two out of a set of triplets or more
# Posted: 12 Sep 2017 10:23pm
What is greater than God, more evil than the devil, the poor have it, the rich need it, and if you eat it, you’ll die?
# Posted: 12 Sep 2017 10:24pm
There was a green house. Inside the green house there was a white house. Inside the white house there was a red house. Inside the red house there were lots of babies. What is it?
# Posted: 12 Sep 2017 10:27pm
Six identical glasses are in a row. The first three glasses are filled with juice, and the last three glasses are empty. By moving only one glass, can you arrange them so that the full and the empty glasses are alternate?
# Posted: 12 Sep 2017 10:28pm
This is an unusual paragraph. I'm curious how quickly you can find out what is so unusual about it. It looks so plain you would think nothing was wrong with it. In fact, nothing is wrong with it! It is unusual though. Study it, and think about it, but you still may not find anything odd. But if you work at it a bit, you might find out. Try to do so without any coaching!
# Posted: 12 Sep 2017 10:30pm
A child is born in Boston, Massachusetts to parents who were both born in Boston, Massachusetts. The child is not a United States citizen. How is this possible?
# Posted: 12 Sep 2017 10:32pm
Captain Frank and some of the boys were exchanging old war stories. Art Bragg offered one about how his grandfather led a battalion against a German division during World War I. Through brilliant maneuvers, he defeated them and captured valuable territory. After the battle he was presented with a sword bearing the inscription "To Captain Bragg for Bravery, Daring and Leadership. World War I. From the Men of Battalion "Captain Frank looked at Art and said, "You really don't expect anyone to believe that yarn, do you?" What's wrong with the story?
# Posted: 12 Sep 2017 10:33pm
How many times can you subtract the number 5 from 25?
# Posted: 12 Sep 2017 10:39pm
Quoting: rockies Six identical glasses are in a row. The first three glasses are filled with juice, and the last three glasses are empty. By moving only one glass, can you arrange them so that the full and the empty glasses are alternate
Pick up the second full glass, pour it into the second empty glass and then put the glass you emptied back where it was.
________________________________
Quoting: rockies How many times can you subtract the number 5 from 25?
Once, then the 25 is 20
# Posted: 12 Sep 2017 10:41pm
Quoting: rockies A child is born in Boston, Massachusetts to parents who were both born in Boston, Massachusetts. The child is not a United States citizen. How is this possible?
Child was born before 1776
bc thunder
# Posted: 12 Sep 2017 11:24pm
NOTHING NO E WORLD WAR 1
. 1 . 2 . >> |
