# Posted: 7 Nov 2014 08:24pm
... came across this today...
old243
# Posted: 7 Nov 2014 09:24pm
Worked in the electrical field most of my working life . I saw many of these fuse bypasses. A favorite was a copper penny in under a screw in fuse. foil across a glass type fuse. A copper wire soldered across a cartridge fuse. .Overfusing screw in fuses. You run into a lot of weird stuff.old243
# Posted: 8 Nov 2014 08:48am
I wonder if you can get the same amperage from low fat cheese
# Posted: 8 Nov 2014 09:59am
bldg insp, depends on the iron content. I suppose it could be used more as a current limiter or a voltage drop for low voltage items.
