# Posted: 21 Dec 2024 09:50am - Edited by: KinAlberta
Interesting video explaining ground wiring.
How Japan Made Their Outlets Safe https://youtu.be/tqClY6PDCW0
# Posted: 21 Dec 2024 02:50pm
Hmmmm Now to think through how I incorporate that concept into my off grid.
# Posted: 21 Dec 2024 05:18pm
Interesting that Japan is now adding grounds to their GFCI protected system.
Quoting: gcrank1 how I incorporate that concept into my off grid.
Wouldn't the basic AC wiring used in the US & Canada remain the same as if we were grid-tied? The exception could be with our service panel neutral-ground bond. That will depend on whether or not the inverter or generator has an internal bond.
In a small cabin system, it would be simple and inexpensive to run each circuit through a GFCI receptacle as the first device on each circuit or use GFCI breakers for everything.
# Posted: 21 Dec 2024 09:09pm
SO, am I better to put my stubby GFCI cord at the gen or up next the cabin input after the long cord?
# Posted: 21 Dec 2024 10:28pm
The GFCI at the generator will protect the line to and into the cabin, so in theory and practice I would think that is better.
Just to be sure you or any reader knows, a GFCI does not need a ground to work. It just compares hot and neutral current and breaks the circuit if an imbalance is sensed. And one can have multiple GFCI daisy chained in the same circuit. Not necessary but no harm.
