Ontario lakeside
# Posted: 19 Oct 2021 07:33pm
Hey all, I had some stuff laying around and thought I would put together a solar powered boat. It was a fun project. I ran the motor directly off the panels so not really a lot of power but we did get it going! I made a video if you would like to see. Im hoping one day to get rid of the 2 stroke outboard!
https://youtu.be/KXla8_0yOLU
# Posted: 19 Oct 2021 08:31pm
Fun thing to do.
Dutch solar RV
# Posted: 19 Oct 2021 09:44pm
Decent little vid! Did you have the panels series or parallel wired? Check the volts output in full sun?
# Posted: 20 Oct 2021 09:42am
Glad to see your back to making videos. I enjoy watching them all and was wondering when the next one will be.
Ontario lakeside
# Posted: 20 Oct 2021 09:42am - Edited by: Ontario lakeside
I had them wired in series but I was using a assortment of bits of wire and wire nuts. I feel like I was never getting the full power. I need to build a better rack and wire it properly.
# Posted: 20 Oct 2021 10:20am
My bigger '12v' panels run 18ishv, Ive seen 36v with 2 in series. The higher the voltage the lighter the wire gauge you can use because the amps are lower compared to running 12v. That motor is 78v? And how many amps? (if rated in watts, A x V = W). The closer you could get to the 'plate rate' the more efficient the motor will run. Probably not enough room on the boat for the optimum number of panels! Think Id go for a min of 3x12v series batteries for 36v charged with 3-4 series panels. You could wire up the bats first to test run then figure out the array/scc required.
Ontario lakeside
# Posted: 21 Oct 2021 06:31pm
Thanks Brettny
It takes so much time to make a video! and YouTube makes it so difficult to find an audience. Im glad you liked it. If you can share it on social media I would appreciate it.
Ontario lakeside
# Posted: 21 Oct 2021 06:33pm
Im going to try some other setups in the spring.
# Posted: 23 Oct 2021 02:57pm
fun stuff, thanks for the video
