<< . 1 . 2 . 3 . 4 . 5 . 6 . >> |
# Posted: 30 Nov 2020 08:46pm
A great resource for building in a northern climate.
https://www.youtube.com/c/GreenEnergyFutures/videos
And a great video on how a rocket stove works.
https://www.youtube.com/watch?v=Sqznv5GDSWc
# Posted: 2 Dec 2020 08:07pm
A good video from Missouri Wind and Solar on using an air source mini split in an off grid building in a cold climate (is Missouri cold?) with a bit of geeky electrical info at the end for the electrically minded
https://www.youtube.com/watch?v=roT0PppSePU
# Posted: 2 Dec 2020 08:10pm
From Exterior Pro Roofing, the differences between standing seam and screw down metal roofing (I had considered screw down until.....).
https://www.youtube.com/watch?v=fdn6tAjemYg
# Posted: 2 Dec 2020 08:18pm
If you are considering an air source heat pump for your off grid cabin one of the things to consider is that with most products you must pay for a technician to come out and fill the lines. With the Mr Cool DIY kit the pipes are pre-charged so you just hook it up yourself and you're good to go.
https://mrcool.com/diy-3rd-generation-e-star/
# Posted: 3 Dec 2020 09:44pm
OSB vs Plywood: What should you choose for your roof deck?
Good info on nail pullout from the Metal Roofing Channel.
https://www.youtube.com/watch?v=rUmhEvoMhKw
# Posted: 3 Dec 2020 09:46pm
Testing Drip Edge Installations from This Old House. Keep water from running down the fascia and backing up under the shingles causing rot.
https://www.youtube.com/watch?v=sDTCTbyyg1s
# Posted: 3 Dec 2020 09:50pm
A brace that can be attached to a standing seam metal roof to prevent your vents from being ripped off the roof from heavy snow or ice slides.
https://www.youtube.com/watch?v=xjqs0ofBYGI
https://snoblox-snojax.com/products/vent-protection/
# Posted: 4 Dec 2020 07:06pm
The Metal Roofing Channel: Calculating the material you need for a standing seam metal roof.
https://www.youtube.com/watch?v=ze81ORYCUfQ
And how to estimate the trim using their online software.
https://www.youtube.com/watch?v=k67lFyuWROk
# Posted: 4 Dec 2020 07:07pm
Metal Roofing Channel: What's the best gauge for a metal roof?
https://www.youtube.com/watch?v=KDnsi4_K1Jg
# Posted: 4 Dec 2020 07:11pm
Building Science website - Their attic sealing guide, written by building scientist Joe Lstiburek. Lots of info and diagrams on how to properly seal pipe and chimney penetrations through the ceiling.
https://www.buildingscience.com/documents/guides-and-manuals/gm-attic-air-sealing-gui de/view
Download the file for free (link in the lower right corner)
# Posted: 15 Dec 2020 07:29pm
The Winnerwell Nomad Camping Stove - one of the best stoves you can buy.
https://www.youtube.com/watch?v=UK4StS9FycE
# Posted: 15 Dec 2020 07:31pm
From Architect Steve baczek - two great videos on construction detailing.
First, a video on floor framing.
https://www.youtube.com/watch?v=XwDhSCV3ixQ
And a video on detailing rafter tails.
https://www.youtube.com/watch?v=9M10uB-76Oo
# Posted: 15 Dec 2020 07:34pm
What to consider when framing your walls to help out the plumbers and electricians (or yourself when you finally get around to doing those tasks).
https://www.youtube.com/watch?v=MAbCAOUcMsI
# Posted: 14 Jan 2021 09:15pm
This site is owned by Ana White, who has a Youtube channel dedicated to DIY home and furniture construction.
https://www.youtube.com/user/knockoffwood
This is the video I watched (on building a mudroom bench) where she mentioned her new site.
https://www.youtube.com/watch?v=fD4iv9N-Y6I
Her new site lets you design cabinets or furniture like tables, benches etc with their free design software, you send them the plans, they cut the plywood and edge band it if you want, then they ship you the precise cut pieces so you can build it.
https://shelfhelpnow.com/
# Posted: 22 Jan 2021 07:26pm
Here's an interesting company that offers unique gifts. It's called "Bespoke Post."
https://www.bespokepost.com/membership?sr=nav_top
Free to join, you pay $45 per month to receive a special gift box containing items pertaining to your interests. Switch a box, skip a box, cancel at any time.
# Posted: 23 Jan 2021 06:14pm
A nice Youtube channel called Crafted Workshop with a guy building a small guest house out back of his main house. He does a lot of in-depth explanation of the entire building process.
https://www.youtube.com/c/craftedworkshop/playlists
So far he's posted 5 videos on the construction but he also builds other things like guitars, sheds and furniture
# Posted: 23 Jan 2021 06:15pm
Matt Risinger explains how to install a freeze proof hose bib through thick walls with exterior insulation.
https://www.youtube.com/watch?v=hgNQcF273Rg
# Posted: 26 Jan 2021 07:40pm
"Matt Bangs Wood" explains how to calculate the amount of building material needed and shows how to use a great online tool from Conxjobs for the task.
https://www.youtube.com/watch?v=eTvWWogMmeY
https://www.conxjobs.com/measure?utm_source=YouTube&utm_medium=Partner&utm_campaign=M BW
# Posted: 3 May 2021 09:45pm - Edited by: rockies
Here's a cool off grid inverter from Cyboinverter that doesn't require a battery bank. It's can be used for heating hot water directly from your PV panels.
https://www.youtube.com/watch?v=LmMsTN8b9Hg
http://www.cyboenergy.com/
http://www.cyboenergy.com/products/offgridHmodeloverview.html
# Posted: 4 May 2021 05:51pm
I was about to ask where you have been rockies
# Posted: 4 May 2021 09:05pm
I've been building
# Posted: 5 May 2021 09:19am
Good stuff. Don’t forget to share pics of your progress
# Posted: 28 Jun 2021 07:42pm
How to keep your roof on (and cabin together) throughout a severe storm. Many people forget to tie the roof rafters or trusses to the walls, or the walls to the foundation. When they do, they tend to use hurricane straps.
Now screws are taking the place of awkward straps. This video from Awesome Framers explains what the screws do and how to install them.
https://www.youtube.com/watch?v=Xtg3CJtytRA
# Posted: 28 Jun 2021 07:44pm
A very cool small house in 291 sq'.
https://www.youtube.com/watch?v=o53VAut3pw8
# Posted: 5 Jan 2022 08:50pm
A good video series about building an inexpensive cabin.
https://www.youtube.com/playlist?list=PL4tQf1xob3LF9z5vtDwCMntbvBs0dg-BY
Adding a bathroom and solar power.
https://www.youtube.com/watch?v=s8qGhzfLiNs
The Camplux tankless propane hot water heater he used needs no electricity.
https://www.amazon.com/gp/product/B083GQPRW6?ie=UTF8&psc=1&linkCode=sl1&tag=tichendor f0f-20&linkId=c5f234a87f5360e5b468d21aeb68f924&language=en_US&ref_=as_li_ss_tl
# Posted: 27 Jan 2022 09:18pm
How to keep your deck from rotting by Matt Risinger.
https://www.youtube.com/watch?v=cXzKQntXSJ0
Did you know there was a specific type of pressure treated lumber for close ground contact?
fiftyfifty
# Posted: 30 Jan 2022 05:31pm
Thanks for the post about the bathroom addition, Rockies. I got a lot of great ideas.
# Posted: 12 Apr 2022 10:28pm
If you're not going to hire an architect you're probably going to design and draft out your cabin plans yourself. Here's a great video on how to dimension your floor plans so that your framers will thank you.
https://www.youtube.com/watch?v=SsId08gmqhY&t=19s
# Posted: 12 Apr 2022 11:46pm
Hey Rockies. Long time no posts. What's been happening? How's the cabin coming along?
# Posted: 27 Jun 2022 08:17pm
A great video on wildfire design.
https://www.youtube.com/watch?v=y_HEHlE-_dE&t=65s
Check out his other vids on permaculture as well.
https://www.youtube.com/c/amillison/videos
