Small Cabin Forum / Useful Links and Resources / Rockies Links
<< . 1 . 2 . 3 . 4 . 5 . 6 . >>
# Posted: 11 Oct 2020 08:35pm
If you're thinking of stock-piling supplies for the winter (or Covid), this site offers prepping supplies at a great price.
https://www.safecastle.com/
# Posted: 11 Oct 2020 08:43pm
This stone sealer was recommended on a 30x40 Architects video as being one of the best.
https://dupontstonetech.com/products/stonetech%C2%AE-bulletproof%C2%AE-sealer
# Posted: 15 Oct 2020 07:14pm
A good carpenter with a lot of useful info and tips.
https://www.youtube.com/c/NextLevelCarpentry/videos
# Posted: 15 Oct 2020 07:17pm
This is a channel out of Australia called Never Too Small that features small homes, cabins and apartments. While many of the projects are urban there are still lots of interesting methods featured on how to make the best use of a small space.
https://www.youtube.com/channel/UC_zQ777U6YTyatP3P1wi3xw
# Posted: 15 Oct 2020 07:18pm
This channel is geared more towards tiny homes on trailers but it still showcases some amazing space solutions.
https://www.youtube.com/user/livingbigtinyhouse
# Posted: 16 Oct 2020 04:29pm
Off grid old school products and methods from Lehman's.
https://www.youtube.com/user/LehmansHardware/videos
# Posted: 16 Oct 2020 04:39pm
A good homesteading channel, Pure Living for Life.
https://www.youtube.com/c/Purelivingforlife/videos
# Posted: 16 Oct 2020 05:22pm
The only place in the main room to put a tv is 6" above a propane heater (and of course there has to be a 12" minimum clearance between the top of the heater and any nearby object).
The heater will only be on once in a while (like when I'm away for a couple of days - it's set on a thermostat) but I don't want the tv so close to the heater should it have to turn on.
SO! I found a pull down tv mount. The tv can be down for viewing (when the heater is off) but can be raised up to 27" when the heater is on. The mount was originally designed for tv's mounted over a fireplace mantel.
https://mantelmount.ca/
# Posted: 17 Oct 2020 06:48pm
A unique method of cabin wall construction.
https://www.youtube.com/watch?v=yn37dFY2pWk
# Posted: 18 Oct 2020 08:01pm - Edited by: rockies
A feature I'll be including in my kitchen, toe kick drawers.
As seen on Ana White's Youtube channel.
https://www.youtube.com/watch?v=jEPgETbfo2E&feature=emb_logo
And some DIY instructions.
https://www.familyhandyman.com/project/how-to-build-under-cabinet-drawers-increase-ki tchen-storage/
# Posted: 18 Oct 2020 08:06pm
A good channel from a home builder called Matt Bangs Wood.
https://www.youtube.com/channel/UCxZgPuWYXhKfSQha2K_ty0A
# Posted: 18 Oct 2020 08:07pm
A beautiful cabin built by a Canadian Castaway.
https://www.youtube.com/watch?v=reKdm-JEoyo
# Posted: 18 Oct 2020 08:14pm
One thing that not many people consider when building their cabin walls is where to put the top plate breaks. The break location can create a point of weakness in the length of the wall and cause it to possibly bow out from the weight of the roof.
This Youtube channel has a lot of great info on building.
https://www.youtube.com/user/gregvancom
And several videos on top plate breaks.
https://www.youtube.com/watch?v=oaMPr4C9fHI
https://www.youtube.com/watch?v=RD_oH8valIU
You may also need to install metal straps.
https://www.youtube.com/watch?v=DutSEsj-XDQ
https://www.youtube.com/watch?v=wKDtvF6vXjM
# Posted: 18 Oct 2020 08:16pm
Another problem that can occur on construction is keeping your floor joists straight.
https://www.youtube.com/watch?v=dAwOVNcgiqs
# Posted: 19 Oct 2020 08:06pm
This Old House: How to lay out locations for valves, hinges and fixtures on the framing.
https://www.youtube.com/watch?v=YktzcBvJCEk
# Posted: 19 Oct 2020 08:12pm
This Old House: How to Size a Kitchen island.
https://www.youtube.com/watch?v=x4y1hYyv0UA
# Posted: 19 Oct 2020 08:14pm
Gregvancom: What do building codes say about drilling through wall studs for plumbing and electrical?
https://www.youtube.com/watch?v=nVFIOAI-IYc
# Posted: 20 Oct 2020 04:32pm - Edited by: rockies
A small Youtube channel (Hammerpedia - only 4 videos) but great info on roughing in a bathroom.
https://www.youtube.com/channel/UCvWNkjCp4lQvYlURjndD6Zg
They also have a link below each video to get a free guide.
# Posted: 21 Oct 2020 08:26pm - Edited by: rockies
A space saving swiveling table top.
If space is at a premium or you want the table to move out of the way you can try this swiveling table base from Lagun.
https://www.lagunusa.com/
https://www.marineteak.co.uk/lagun-table-mount/lagun-adjustable-swivelling-cockpit-ta ble-mounting-system-331
If you want to see it in action there are numerous videos on Youtube.
https://www.youtube.com/results?search_query=lagun+table+mounting+system
# Posted: 23 Oct 2020 07:33pm
This is a $20 DIY version of the Laguna table mount.
https://www.youtube.com/watch?v=owluWNKs7dU
# Posted: 23 Oct 2020 07:34pm
A really nice upgrade on a wood fired hot tub.
https://www.youtube.com/user/Alumitubs
https://alumitubs.com/
# Posted: 25 Oct 2020 07:23pm
So you're getting tired of all the maintenance and repair on your exterior wood trim and decide to change it to PVC (which being plastic doesn't rot) but you want to paint it a dark color. That's an issue with plastic exterior materials because the darker colors absorb more heat from the sun and can soften and warp.
However, in this video from Protrade Craft they discuss different kinds of dark paint (even black) that can be used on exterior PVC trim (about minut4e 7:55).
https://www.youtube.com/watch?v=opmk9NoN9xE
This is the best paint they recommend.
https://www.aquasurtech-oem.com/products-d200.php
# Posted: 25 Oct 2020 07:29pm
In the same video from Protrade craft they discuss what kind of material you can safely use below grade (or in contact with the earth) that won't be damaged by water (starting at minute one).
The 3/4" thick boards can be used to enclose your pier foundation.
https://azekexteriors.com/products/sheets
# Posted: 25 Oct 2020 07:34pm
Where do you put the headers in an exterior wall? Most people put them at the top of the window opening and then if there is any additional space above it they use cripple studs up to the top plate.
However, to increase the lateral stability of the wall you should put the header up against the top plate and they frame in a lower top sill.
This article from the Journal of Light Construction explains the process (you can sign up for free and download the article in pdf format)
https://www.jlconline.com/how-to/framing/exterior-wall-headers_o
# Posted: 25 Oct 2020 07:36pm
This is a great video from a tiny house builder in Colorado featuring his own home.
There's a cool kitchen counter/dining table feature at minute 4:55.
https://www.youtube.com/watch?v=TYgbcUbFSk0
# Posted: 25 Oct 2020 07:38pm
This is a great Youtube channel by Levi Kelly that mostly features small airbnb's but they all have some very cool features that could be used in a small cabin.
https://www.youtube.com/channel/UC3hEhxxlq9OWXWp4t4uYXKw
# Posted: 25 Oct 2020 07:47pm
A couple of really interesting videos from Noah Bradley and Handmade House TV on how to design and build an attractive cabin.
https://www.youtube.com/channel/UCfNcyHyZX9VoY2feVgztBnw
https://www.youtube.com/watch?v=YhbkODJ01f8
https://www.youtube.com/watch?v=dR5j9KIYpT8
His website.
https://handmadehouses.com/
You can also sign up for his free weekly newsletter.
# Posted: 28 Oct 2020 07:09pm - Edited by: rockies
Matt Risinger - Six critical exterior door components.
https://www.youtube.com/watch?v=34EXkYVAv6M
Endura Door Products.
https://www.enduraproducts.com/
And why every exterior door must have a sill pan.
https://www.youtube.com/watch?v=n8qUztgbGYA
# Posted: 28 Oct 2020 07:11pm
Matt Risinger - Choosing windows- fiberglass or vinyl?
https://www.youtube.com/watch?v=KyQ4YskSFZs
Window Buying Guide.
https://www.youtube.com/watch?v=wyyM5es8MeI
# Posted: 28 Oct 2020 07:13pm
Risinger : 3 tips for a flawless paint finish.
https://www.youtube.com/watch?v=yx6-Q03tfg0
A link to the Big Stretch caulk.
https://www.sashco.com/products/big-stretch/
