# Posted: 7 May 2019 07:53pm - Edited by: rockies
Reply Quote
On the Green Building Advisor site a gentleman is building his own house and he decided to use Sturdimount cellular PVC mounting blocks for his exterior lights.
https://www.greenbuildingadvisor.com/article/saving-sustainably-installing-trim-sidin g
https://www.sturdimount.com/
You can also get mounts for electrical outlets, water spigots, dryer vents, etc. The main advantage to using these mounts is that there is a water tight seal around the fixture and you have a nice clean connection around the mount to the siding.
As with any hole drilled through your exterior wall you should add a flashing membrane first, such as those made by Quickflash.
http://www.quickflashproducts.com/index.html
http://www.quickflashproducts.com/products_electrical.html
