Small Cabin Forum / Useful Links and Resources / Phenolic Laminate For Insulated SIPs Panels Tiny Home For Sale
mark57
# Posted: 15 Nov 2018 08:50am
Phenolic Laminate For Insulated SIPs Panels Tiny Home For Sale:
Contact Mark at: hytechpowerllc@yahoo.com
Visit Quantum Tiny Homes: https://sales5450.wixsite.com/quantum-tiny-homes
18 Foot Ultra-Lightweight, Insulated Composite Tiny Home
The Next Generation of Tiny Homes
Build your own 18 Foot Ultra-Lightweight, Insulated Composite Tiny Home that can be removed from the Tiny Home Trailer and be placed on the ground or on a foundation.
1,680 Square Feet of Phenolic Laminate for sale: $1,600 FOB Boyton Beach, Florida
Phenolic Laminate Dimensions: 8 Feet Width X 210 Feet Length (1,680 Square Feet)
The Phenolic Laminate is on two 4 Foot Pallets and weighs approximately 690 Lbs.
18 Foot Ultra-Lightweight, Insulated Composite Tiny Home Shell Only Weighs: 864 Lbs
With the 1,680 Square Feet of Phenolic Laminate we are selling you can construct your own 18 Foot Ultra-Lightweight, Weather-Proof, Insulated Tiny Home.
Total Cost To Manufacture Your Ultra-Lightweight, Insulated Tiny Home Shell: $3,121
1,680 Sq. Ft. of Phenolic Laminate: $1,600
436 Sq. Ft. of 4” Thick EPS Foam: $524
331 Sq. Ft. of 5” Thick EPS Foam: $497
Moisture Cure Polyurethane Adhesive: $500
Total Cost: $3,121
Benefits and Advantages of Phenolic Laminate Insulated SIPs Tiny Homes:
1) Ultra-Lightweight Structure can be removed from the Tiny Home Trailer and be placed on the ground or on a foundation.
2) Ultra-Lightweight Structure reduces fuel consumption costs.
3) Ultra-Lightweight Structure allows lesser capacity vehicles to be used for the transportation of your Tiny Home.
4) Lightweight Tiny Home Trailer can be used to reduce cost and weight.
5) No Mold, No Rot, No Mildew guarantees Healthy Interior Air Quality.
6) Energy Efficient Insulated Envelope reduces Heating and Cooling Cost.
7) Insulated Composite Tiny Homes are much quieter than wood or steel frame Tiny Homes
8) No possibility of Termite Damage since there is no wood used for the Tiny Home structure.
9) Monolithic Composite Structure will not warp or dis-assemble during transportation like traditional wood frame Tiny Homes.
10) The Entire Exterior Envelope in weatherproof and waterproof.
Visit our Quantum Tiny Homes website to discover all of the Benefits and Advantages of Ultra-Lightweight, Insulated Composite Tiny Homes
Phenolic Laminate is a Fireproof, High-Strength Fiberglass Laminate that can be used to manufacture Ultra-Lightweight Phenolic Structural Insulated Panels (SIPs) to manufacture Composite Tiny Homes.
[img=null]null[/img]
8 Ft. Width X 18 Ft. Length X 10 Ft. Height Tiny Home Shell Only Weighs: 864 Lbs
Phenolic SIPs Wall Panels with 4” Thick EPS Foam
Phenolic SIPs Roof Panels with 5” Thick EPS Foam
Phenolic SIPs Floor Panel with 5” Thick EPS Foam
The Tiny Home Shell weight specification of 864 Lbs does not include windows, doors, siding, roof covering or internal components (furniture, appliances, etc.)
There is no need for exterior siding, interior sheetrock or interior paneling. Exterior and interior paint can be applied directly to the interior walls, interior ceiling and exterior walls. An elastomer roof membrane can be applied directly to the roof panels or steel roofing can be applied to the roof panels.
The completed Phenolic Laminate Insulated SIPs Tiny Home will be 100% waterproof. There will be no visible seams in the interior or exterior of the completed Phenolic Laminate Insulated SIPs Tiny Home.
