Small Cabin Forum / Useful Links and Resources / A BioEthanol Fireplace
# Posted: 31 Oct 2018 08:07pm - Edited by: rockies
Some people have a very tiny cabin and want to enjoy a fire but don't need a lot of heat blasting into the room from a standard fireplace or wood stove.
These bioethanol heaters use a plant based product that when burned produces some heat but no harmful fumes - just steam and carbon dioxide. You also don't need a chimney or flue. Comes in electric and non-electric versions.
https://ecosmartfire.com/ca/en/
https://ecosmartfire.com/ca/en/bioethanol-fuel/
https://e-nrg.com/ca/en/
Kyle_t63
# Posted: 6 Apr 2020 10:49am - Edited by: Kyle_t63
I agree with your comment, we have a small summer house and the hear output and look are perfect. No smoke and no maintenance.
The installation was quite simple, just beware to have a fireproof wall that supports the weight.
I found mine here
greetings!
Kyle
Cebolla
# Posted: 27 Apr 2021 12:07pm
Never use that to heat a small cabin! Eventually the fire will consume the oxygen in the cabin and start to generate carbon monoxide! That should only be used in well ventilated spaces!
