# Posted: 22 Oct 2018 06:30pm
If you have a very small bathroom but still want to use a dual flush toilet then this option will add about 12" of floor space in front.
http://www.ca.kohler.com/onlinecatalog/detail.jsp?item=25060202&prod_num=6299
# Posted: 22 Oct 2018 09:24pm
Expensive, aren't they? I've installed them for high end projects and they run $2k - $5k....
spoofer
# Posted: 27 Oct 2018 09:57pm
$873
# Posted: 27 Oct 2018 11:01pm - Edited by: ICC
$873 (CAN) gets you the toilet, in white, colors are an extra 300-400, but not the in the wall works (2x4 wall) at $956 plus $235 for the actuator. =$2064 CAN = $1571 US, today.
# Posted: 28 Oct 2018 11:24am
I was counting the installation charge...you have to run power to the toilet too, right?
and every wall-hung toilet I've ever encountered ended up leaking eventually....just my experiences.....
# Posted: 28 Oct 2018 11:44am
I would never install one for myself.
# Posted: 29 Oct 2018 12:32am
Hmmm....just wondering what happens if there are problems with the tank that is in the wall? If something needs tightening or replacing (ie: valve). Do you need to rip out the wall to fix it? No tanks.
Cowracer
# Posted: 29 Oct 2018 09:23am
I've bought CARS for less than that.
Tim
# Posted: 29 Oct 2018 10:46am
But thanks for posting it Rockies.......it might help someone with space considerations, as you said.....
# Posted: 29 Oct 2018 07:23pm
Hattie: there is an access panel in the wall above the bowl if a repair is needed.
The unit is pricey, but it's an option for very tight bathrooms.
