# Posted: 18 Apr 2018 07:45pm
Reply Quote
I'm installing a couple of round porthole windows in my cabin and the subject came up of how to case the windows. I didn't want to cobble together a bunch of short pieces of wood and then router them into a circle (too many joints for water to get into).
I just found this article which suggested using a 4x8 sheet of cellular PVC and cutting out the casings in one piece.
http://www.finehomebuilding.com/2010/11/11/making-a-beaded-circular-casing
Anyone else planning on installing a round (or arched) window?
Princelake
# Posted: 18 Apr 2018 08:36pm
Reply Quote
I've always cut a pile of casing into small pieces with an angle on it. Nailed them all on putty them and sanded the edges smooth to appear round. You then have the matching casing with the rest of the place
# Posted: 18 Apr 2018 08:57pm
Reply Quote
Yes, but you still have a lot of joints, which can be problematic for exterior applications. PVC also has the advantage of not being wood, so no swelling, warping or rot issues. For a molding that isn't just flat stock you could set your router to try and match existing interior trim details but your exterior trim would probably be flat.
# Posted: 18 Apr 2018 09:53pm
Reply Quote
I usually use plywood and cut it to fit......Yes it is wood, but can use a select grade and caulk/seal/paint
