Small Cabin Forum / Useful Links and Resources / Municipal Light Pole Bases for Concrete Piers?
# Posted: 27 Feb 2018 07:19pm
I wonder if a concrete base usually used for anchoring light poles could be used for a cabin pier? They can come in lengths up to 90" and are precast.
http://www.langleyconcretegroup.com/uploads/tech_drawings/Misc.%20Precast/M-1.1.pdf
# Posted: 27 Feb 2018 07:31pm
Ah, got to love it when they mix metric and English units. Even better, they don't specify what metric units they are using and leave it to you to guess.
I suspect they'd make good bases if you have the equipment to dig the hole and drop them in place.
# Posted: 27 Feb 2018 07:38pm
I just got an email from them and they say that their concrete has a compressive strength of 5000 psi or more.
Littlecooner
# Posted: 27 Feb 2018 08:51pm
These should work.
# Posted: 1 Mar 2018 02:40pm - Edited by: KinAlberta
A benefit might be an ability to drop them a few times to compress the ground at the bottom of the hole.
More:
https://www.westconprecast.com/precast-products/electric-utility/light-pole-precast-b ase/
Now this is interesting:
Picture here:
https://www.westconprecast.com/precast-products/precast-buildings/
Westcon Precast Alberta > Precast Concrete Buildings > Precast Concrete Cabins
Looking for that secure cabin that you don’t have to worry about? We have your back! Not only are Westcon Precast Cabins durable and fire resistant, but they are also available in numerous finishes and sizes. Whether you are looking for 1 season, 2.5 season, or 4 season cabins, Westcon Precast Concrete Cabins are designed to meet Alberta’s harsh climate and still look good season after season.
https://www.westconprecast.com/precast-products/precast-buildings/precast-concrete-ca bins/
tverga
# Posted: 1 Mar 2018 04:59pm
Are they hollow?
# Posted: 1 Mar 2018 06:13pm - Edited by: rockies
These cabins and shelters are available in two standard sizes; each wall panel is a precast concrete unit which can be easily assembled at remote locations. Once assembled, the walls are internally and externally coated with Westcon’s priority stain, ensuring it is not only climate friendly and weather proof, but attractive in any setting.
Westcon offers customized precast cabins and shelters as per client specifications and requirement.
I wonder how the insulation is installed?
