# Posted: 22 Feb 2017 06:44pm
Do not mix urine and solids.
http://www.inthewilderness.net/2017/02/20/the-indoor-outhouse/
http://www.ecovita.net/privy.html
brooksm29
# Posted: 23 Feb 2017 03:57am
I too found this out the hard way. I do a composting toilet (county regs) and now have a 2 holer. 1 for #1 and 1 for #2.
# Posted: 23 Feb 2017 11:29am
Really depends on the size of the setup. Who's using it. Male/female. How often.
I cheerfully mix everything with a larger composting toilet. And assuming the drain/vent are working properly. No problems.
I cheerfully mix everything in a 5 gallon dry compost bucket toilet. If the gf is visiting I a) empty more often. or b) ask her to use the bed pan for #1s. But no big deal if she doesn't.
I also use: * Bokashi in my dry material. I've posted on this regularly. he he. The advantages are two fold: One, no odour. Two, eliminates (I'm on a roll, dang) dangerous pathogens. * lots of carbon. usually straw. and ask everyone to put the tp in the toilet. carbon helps the high nitrogen digest.
brooksm29
# Posted: 23 Feb 2017 08:40pm
I think the time I discovered we had a problem there were 7 females and 5 males. Bad combo, bad mess, crappy (haha) job...
Wilbour
# Posted: 23 Feb 2017 10:42pm
There are a couple of things you have to keep in mind when composting human waste:
#1
and
#2
Smawgunner
# Posted: 24 Feb 2017 07:45am
I found out from a friend who discovered this the hard way. I took his advice and came up with this design. It's been a year and a half and it is just now full. Dry as a bone in there too. http://www.small-cabin.com/forum/3_6192_0.html
NeilHug
# Posted: 13 Sep 2020 11:57am - Edited by: NeilHug
Hey! I know it's been three years but I came across this post and couldn't just go past it. Now I see that this mistake is not only mine I guess we just have to find it out the hard way, to remember it for life :D Anyway, have you ever tried to do a urine test for the one you use? I did, just for interest.. These tests showed a lot of natural and chemical components in it. Had no idea what I was using
