Small Cabin Forum / Useful Links and Resources / High Lifter Gravity Water Pump - No Fuel or Electricity Needed
# Posted: 3 Oct 2016 09:20pm
http://www.humboldtsolarwaterpump.com/high-lifter-gravity-water-pump-for-your-off-gri d-water-system/
Atlincabin
# Posted: 6 Oct 2016 09:40am
This is basically a fancy hydraulic ram pump that can be built from readily-available plumbing supplies for maybe $20-40 in materials if you want to do it yourself. Google "hydraulic ram pump" and there are a number of diagrams that show how. I built one over 30 years ago for my off-grid house and it worked faithfully for years. It will pump about 10% of the water flow approximately 8x the head (in other words if your downhill drop is 10 feet, it can pump to about 80 feet above the pump itself, thus a gain of about 70 feet of elevation).
# Posted: 7 Oct 2016 09:56am
That's pretty neat if you live by a waterfall.
Atlincabin
# Posted: 8 Oct 2016 11:54pm
The ram pump will work with only minimal drop. My old one had a drop of about 2.5 feet and I was able to pump water into a tank about 20 feet above the pump. That was enough to give us a reasonable, but not city-type, water pressure inside the house.
