Small Cabin Forum / Useful Links and Resources / Deck Flosser - Cleans out the spaces between deck boards
# Posted: 7 Jul 2015 08:42pm
Saw this on a cottage show. It gets the pine needles, leaves and dirt out of the spaces between deck boards. Apparently if that stuff builds up, it holds moisture between the boards and decreases the life of your deck by half.
http://mkrittenhouse.com/us/deck-flosser
murphymunday
# Posted: 8 Jul 2015 09:16am
Thanks for sharing! A good tool to keep around, indeed.
littlesalmon4
# Posted: 8 Jul 2015 02:10pm
The other thing you can do when building your deck is to apply roofing ice shied to the tops of the joists before you put down the decking. Moisture then can not enter through the top of the joist to rot it.
Malamute
# Posted: 9 Jul 2015 01:12am
Ah. I use a sawzall blade in my hand. I get rocks, dog hair and other flotsam accumulate, then a layer of dirt/sand. Its under the roof overhang though, and pretty dry climate.
I've seen the roofing paper used. It wasnt all that great. Treated lumber would be good for the frame underneath in damp climates, or roofing tar on the top of the frame.
littlesalmon4
# Posted: 9 Jul 2015 12:24pm
The ice shield is actualy a rubber like membrane.
Malamute
# Posted: 9 Jul 2015 01:59pm
Yes, indeed it is. My reading comprehension may improve if I slept better.
