Bushman
# Posted: 30 Jan 2014 04:52pm
I'm just looking at building a basic 12 x 12 Plywood cabin and wondering where you folks had found your designs or drawings for building your cabins. Just looking for the basic K.I.S.S design.
# Posted: 30 Jan 2014 05:09pm
http://www.motherearthnews.com/diy/build-this-cozy-cabin.aspx
This is the design I based all of my "cozy cabin" drawings on. It could be altered to the size you need pretty easily. You wouldn't need to keep the porch part. If you used a simple gable roof with a ridge beam and then used a post at one end (under the end of the ridge beam and running all the way down to the floor inside one of the gable walls) you could use that post later on to add on another ridge beam in the future and expand the cabin into a 12x16 or 12x20 if you wanted.
ChuckDynasty
# Posted: 31 Jan 2014 07:11pm
I can email you 12x12 2x6 construction plans.
revrandy
# Posted: 10 Feb 2014 02:09pm
ChuckDynasty,
I saw your offer and decided to register to see if I can get a copy of the construction plans as well. We are building a 12x12 this spring and are in the plan shopping stage.
