# Posted: 6 Jun 2012 09:47pm
Ok if you have 1290 x 1380 x 500 feet how many acres do you have??? It is a triangle peice of land and any help would be appreciated!!!
johng
# Posted: 6 Jun 2012 09:54pm - Edited by: johng
We need to know which dimensions are where. maybe this will help. http://www.mathgoodies.com/lessons/vol1/area_triangle.html
...btw, there are 43560 square feet per acre.
johng
# Posted: 6 Jun 2012 09:59pm - Edited by: johng
Guessing at 1290 as base and 500 as height you have about 7.4 acres.
# Posted: 6 Jun 2012 10:22pm
The lenght is 1380 & 1290 and wide 500 feet. this is a triangle peice of land.
# Posted: 6 Jun 2012 11:28pm - Edited by: neb
If I take 1380 x 500 =690000 half would be 345000 divide by 43560 would equal 7.9 acres is this close?? If one side is shorter it would be some what less then 7.9. What do you think????
# Posted: 6 Jun 2012 11:31pm
# Posted: 7 Jun 2012 12:27am
Quoting: neb Ok if you have 1290 x 1380 x 500 feet how many acres do you have??? It is a triangle peice of land and any help would be appreciated!!!
OK, multiple 500 X 1380, then divide by 2 (in half because its a triangle) and you have 345,000 sq feet. There is 43,560 sq feet in an acre, so you have 7.92 acres
# Posted: 7 Jun 2012 07:25am
I think these measurements are all high as this is an irregular triangle so the standard base and height approach does not work. Use Herons formula. Look the formula up if you like math and do it by hand OR use Area Calculator . The area comes out to 322490.88 square feet or about 7.4 acres.
# Posted: 7 Jun 2012 10:34am
I think the formula we used is accurate enough. An irregular triangle is just more like a prallelogram cut in half diagonally. If we are only differing by .2 acres (I came up with 7.2, you get 7.4), split the difference, its .1, not bad either way for a bunch of rookies.
Now a trapezoid cut in half....
# Posted: 7 Jun 2012 11:49am
Sorry - my Physics background coming into play (not the Astro-physics portion - where answers are often give or take a few million light years).
AYP1909
# Posted: 7 Jun 2012 01:33pm
razmichael is correct at 7.4034 acres.
# Posted: 7 Jun 2012 08:21pm
Thanks for all the help. I am not the best a math!!!!!!!!!!
# Posted: 29 Jun 2012 12:51pm
just google search conversions and pick the top link
