customrunner
# Posted: 8 Dec 2011 02:24pm - Edited by: customrunner
  was serching for info on how many batterys I wood need for my solar setup and came across this calculator seems nice and simple, I will be useing 6V batterys with my system. http://www.freesunpower.com/system_sizing.php
Erins#1Mom
# Posted: 8 Dec 2011 09:40pm
  This link is a keeper.  Have added to favorites.
Bzzzzzt
# Posted: 8 Dec 2011 10:07pm
  That link says I need 6 batteries to power 200 watts of light for 4 hours a day. I think that's a tad excessive.
customrunner
# Posted: 8 Dec 2011 10:46pm - Edited by: customrunner
  Bzzzzzt I think you must have done it wrong it shows 4 batteries but remember there 12V at 105Ahs you could run one baterie if it has the 400 ahs
# Posted: 8 Dec 2011 10:55pm
  200 watts lights for 4 hours a day comes out to 4 x 105AH batteries using the calculator, which makes sense if you run the math manually.  Keep in mind that the default results are based on 3 days use depleting the battery to 50% only.  200 watts 4 hours a day for 3 days is 2400 watthours.  Double this for 50% and that's 4800.  Divide by 12 for a 12 volt system and you get 400 AH - hence four batteries at the size used.  You can convert initially to AH as well - 200/12 is 16.67 amps.  12 hours total gives 200 AH.  Double the capacity to keep the discharge at no more than 50% and you get 4 batteries.  I've used this calculator on a number of occasions.
Rob_O
# Posted: 8 Dec 2011 11:31pm
 Quoting: Bzzzzzt That link says I need 6 batteries to power 200 watts of light for 4 hours a day. I think that's a tad excessive.
  800 watt/hours for 3 days comes up to 200 amp/hours, 50% capacity for 4 100 AH batteries. More than 50% when you figure in inverter losses
