# Posted: 9 Nov 2011 01:24pm
This is a website that uses results from years of soil surveys from across the country. Some areas are not listed as conditions can vary too much within short distances. The load bearing ability od the soil determines how well the building load will be supported, whether there is risk of settling. Some soils can provide better lateral support to piers than others. Some soils are real problems; when the clay content is high for example.
Web Soil Survey
jjpaul
# Posted: 29 Dec 2013 07:52pm
This Soil Survey is very informative, thank you. According to the survey I have 14-25" water table November thru May. I was planning to build on concrete piers, would I be better off with gravel and concrete blocks on the surface for a 12x16? Is a water table like this a plus for a sand point? I guess a dry well is out. Thanks again. -JJ
# Posted: 30 Dec 2013 11:57am
In some jurisdictions, when a soils report is required for construction of a building, the jurisdiction may waive the soils report requirement if the applicant can show enough reports from adjacent lots to show that the soil locally is consistently of a certain character. But, jurisdictions usually don't advertise that they will waive the requirement. You have to ask and be able to make your case with supporting information, which the site shown above may provide.
