<< . 1 . 2 . |
# Posted: 15 Oct 2020 01:09pm
Reply Quote
In this situation with a 12' wide loft I dont think it really matters if you add another stud under the loft floor joist or screw directly to the side of the wall stud. The beat way would be to put the loft floor joist right ontop of the wall top plate but you take away head room in the loft.
Why cant you properly insulate?
# Posted: 15 Oct 2020 01:12pm
Reply Quote
Also I have a 20yr old T1 11 garage that has a trim board at 8' even with Z flashing that trim board has caused the siding to completely rot behind it. It's been like for for at least 9yrs.
I would remove that trim board above the front porch. In one pic I alreaty see it turning gray from water. Is there a reason you didnt put larger gable end overhangs?
# Posted: 15 Oct 2020 01:35pm
Reply Quote
Quoting: Nate R I'm saying hanging the loft joists off a standard 2x stud, not over a jack stud (or nothced 4x)....
Show us the math. Dead loads, live loads, etc.
# Posted: 15 Oct 2020 01:36pm
Reply Quote
Quoting: Brettny The best way would be to put the loft floor joist right on top of the wall top plate
Show us the math.
# Posted: 15 Oct 2020 03:27pm
Reply Quote
What's to show? Your putting the floor joist ontop of the load bearing wall. Fasteners are less important this way.
Nate R
# Posted: 15 Oct 2020 07:24pm
Reply Quote
Both me and Willie were just trying to understand what your'e saying is the "right way..." and I'm saying is the alternative even wrong in this case?
So, 12 foot wide building. One side is taking 6 feet of the joist load, by 2 feet (24 oc.) So each joist end is handling 12 SF. For a sleeping area, what's the live load max, 30 PSF? Dead is what? 10? 15? We're talking max of 540 lbs on that point at 15 lbs dead, 30 lbs live.
If it's on top of a stud, or notched into it, worst case, you need a 1.6 square inch area for bearing. http://sprucepinefir.us/wp-content/uploads/2017/03/Base-Design-Values-for-SPFs-and-SP F.pdf
You could but a 1/2" thick notch in the stud to catch the joist, and use 2-3 of the simpson SDS screws to hold it there. You could probably not even notch and just bolt the joist to the side of the stud with those screws.
https://p.widencdn.net/r5ahu1/C-F-2019TECHSUP-p44and51and79and114and129.pdf2
JulieG
# Posted: 2 Mar 2021 01:35am
Reply Quote
I like the details you provided. I want to build a 12x20 cabin also and currently in the research phase. Lumber prices are so high so I am not sure when I can start my project. Did you have any venting of your roof? Did you add insulation to the roof or under the floor?
# Posted: 2 Mar 2021 10:49am
Reply Quote
Hey man you're cabin loks great. I think you're build will be fine. Great to see the kids and that you're out teaching them to hunt. Might I suggest getting a book on plants, trees n such. And how to identify n use them. Would be great information for the family. Time to get some tool belts for those helpers.
Keep up the great work coach !
Shadyacres
# Posted: 15 Oct 2021 03:54pm
Reply Quote
Looks pretty good but I would definitely remove that 2x4 you have running across the front above your porch. It is trapping moisture in behind it and already discoloring the siding.
<< . 1 . 2 . |
