<< . 1 . 2 . 3 . 4 . >> |
# Posted: 28 Oct 2011 11:42am
Your stovepipe should be above the highest peak for proper draw. We went with the corner but paying for all the stainless double wall was not fun :( In the long run though I think it is better to spend the money and put it where it gives you the most leftover workable space-that way you won't regret it. Good luck!
Mark2011
# Posted: 28 Oct 2011 01:34pm
That is what I was thinking, also hoping not. I looked at your picture with your pipe. I guess i'll be placing my stove in the middle and since its open, just running black pipe up to the roof and then putting an insulated cap at the peak to outside.
# Posted: 28 Oct 2011 01:40pm
Be careful with that futon though-you don't want to awake with your bed on fire!!!! Maybe the futon could be moved to a safer distance.
Montanan
# Posted: 28 Oct 2011 03:56pm
We did the same as trollbridge- put it in the corner, as that worked the best for us in terms of usable space. But yes, that double wall chimney pipe was $$$ and wow- HEAVY! We had a heckuva time getting the pipe all set up- especially the support box. Ugh. But I tell ya, it works GREAT. We have excellent draw and it heats the cabin nicely. FYI- there are very specific guidelines for installation and clearances, so follow the directions!
soundandfurycabin
# Posted: 28 Oct 2011 05:19pm
Too late now, but sometimes it's cheaper to build the cabin a couple feet longer than to pay for all the extra chimney pipe!
marker2011
# Posted: 29 Oct 2011 07:59pm
Thanks guys for the information
Well the futon is just for a spare bed, it will be used mostly as a sofa. Our bed will be on the loft. Also its an airtight wood stove with a glass door. Im going to put it in the middle or i'll have to spend alot more of insulated pipe to go outside. plus in the middle it'll look nicer.
Mark2011
# Posted: 4 Nov 2011 12:57pm
Just thought I drop in and add some more pictures.
I found a complete kitchen cabinet set for free on kijiji. I just had to remove them. I only had room in my truck to bring up half. Im going to bring up some more and then sell the rest. I have all the insulation and vapour barrier in. Only spot I need to put some is behind where the wood stove is going. Im going to build a stone base for it. As you can see in the picture.
# Posted: 4 Nov 2011 04:14pm
Nice looking wood stove! Did you decide to go with the corner placement? I like the stone very much!!
marker2011
# Posted: 8 Nov 2011 10:13am
Thanks, the wood stove is going to work great for the winter.
Yea I decide to go in the corner, i'd spend a little extra to save space in the cabin. It just makes more sense to put it in the corner.
Built my stone base this past weekend and set up the kitchen area. Plus did the wiring for some outlets.
Its coming along, also getting very cold up there.
Nirky
# Posted: 15 Nov 2011 09:19pm
This looks like a wonderful cabin. Have been following your progress, looking forward to seeing more interior & exterior pictures.
Mark2011
# Posted: 12 Dec 2011 12:31pm
Hey all!
So I started putting up the pine interior walls this weekend. I only bought a small amount to get started. I started in the loft area up stairs, so once that area is done we can block it off and have it has a sleeping area. It looks pretty nice.
Enjoy.
Mark2011
# Posted: 12 Dec 2011 12:33pm
Here's a picture of the wood stove with its stone base. Works great! And the kitchen set up. I got this whole kitchen for free + I still have 6 other cabinets that I'm not going to use. There's a picture of the stove/oven I bought, works great on a 20lb propane tank.
# Posted: 12 Dec 2011 02:57pm
Looks real nice. I like your stove/oven! Your wood upstairs and your stone for your wood stove sure looks great! Good find for free(cabinets). Your really coming along nicely!!! Congrats!
Mark2011
# Posted: 13 Dec 2011 01:48pm
Thanks, It sure is coming along nicely. I'm going up for 2-3 days over my xmas week off from work. Going to buy a whole lot of pine board and get the majority of walls finished and also lay down some red pine floorings.
I fould this guy who mills pine wood. He has over 100 different shapes, size and etc of what he can mill. I'm doing the interior walls with a 6" wide t&g V joint board. It costs .35 cent a foot which is pretty good price considing the same pine board is at home depot for .50-.60 a foot.
As for the flooring, he has red pine 6" wide t&g planks for .45 a foot. I bought a few boards to get a feel for them. Red pine isn't has soft as I was told by people. He also sells nice pine siding. Which i'll be doing in the spring.
This winter the focus is to finish the inside and once spring comes around, finish up the outside. If all goes to plan this cottage would have taken 11 months to complete on most weekends.
Montanan
# Posted: 13 Dec 2011 02:33pm
Looking great- congrats on all the good finds! I'll be watching for updates with the walls and floors in.
customrunner
# Posted: 13 Dec 2011 06:42pm
Mark2011 Were are you getting your pine sounds like a great price. Thanks chad
Mark2011
# Posted: 14 Dec 2011 08:12pm
Thanks everyone.
I can't wait to have some more pine done on the walls/floor. Its going to look very sharp and rustic.
On my way up this past weekend I found a deer skin in the middle of the road that had already been cleaned. I'm guessing a hunter had it in the back of their truck and lost it. I grad it anyways. Not sure what i'll use it for but I didn't want to see it go to waste.
Now that the walls/floor are coming along. I'm starting to figure out a way to heat water for the shower. I think I might use a 12 volt pump and put some plastic pipes in before I close everything up in the kitchen.
Mark2011
# Posted: 14 Dec 2011 08:14pm
Here's a picture of the whole stove set up. It worked out pretty good. 12112011314.jpg
marker2011
# Posted: 13 Mar 2012 02:15pm
Just wondering does anyone know where and how much septic holding tanks are?
# Posted: 13 Mar 2012 02:26pm
Do you mean the big concrete ones for houses...or small ones for an outhouse???
Mark2011
# Posted: 14 Mar 2012 08:58am
I mean the big water plastic ones.
Mark2011
# Posted: 14 Mar 2012 08:59am
Here's an update on the cabin
Cheers
Mark2011
# Posted: 14 Mar 2012 09:01am
I'll try and post some more pictures after this weekend. The inside is pretty much done. Next step is to finish the wood floor and put up a railing.
# Posted: 15 Mar 2012 03:58pm
Wow...you have certainly been busy haven't you? Looks great!!!
About your septic tank question I would suggest you maybe ask on a separate thread....you may get many more suggestions and there may be others interested in the same info too. Do you have codes you have to meet?
Mark2011
# Posted: 16 Apr 2012 03:59pm
New pictures
Mark2011
# Posted: 16 Apr 2012 04:00pm
More new pictures
Montanan
# Posted: 17 Apr 2012 12:54pm
Wow- great progress! Looking good.
mark2010
# Posted: 19 Apr 2012 02:15pm
Thanks Montanan,
Its coming along nicely. I can't wait to get the 3 other sides of the cabin finished on the outside. Hopefully build my water tower soon so we can take showers and have running water inside.
# Posted: 22 Apr 2012 12:26pm
mark2010 - Your place is coming along great! I really like the placement of your staircase (great space saver). Nice work!!!
Mark2011
# Posted: 22 May 2012 01:29pm
Hey everyone!
So the cabin is almost finished and I just thought I'd come give an update with some photos!
Enjoy
