Fireandkaolin
# Posted: 23 Jul 2018 09:34pm
Hi folks, so I'm new here and I'm sorry if this question has already been asked, but I was wondering if anyone had any experience with building in Vermont (specifically centralish area)? I was curious about, how much of a hassle it was (if any) dealing with vermont building inspectors and such. I know it will vary from town to town, but I just wanted to get a feel for it before I make any decisions or start looking at properties. Thanks.
# Posted: 23 Jul 2018 10:12pm - Edited by: toyota_mdt_tech
What you are doing it great. It can vary to very nice people, to nazi HOA's and rule (Bruce Peninsula in Ontario comes to mind) and the tight restrictions.
You can get a general idea on whats allowed probably from the county website in the county you are looking at. You want to see if there is a minimum square footage that can work for you, what else is required, ie can a privy work or do you need a full septic etc.
Eddy G
# Posted: 24 Jul 2018 12:28pm
Ask the locals. If there is an area your interested in stop at the local general store and ask a few questions. People are mostly helpful. I've gotten more useful information at the town transfer station (town dump) then town hall....
Fireandkaolin
# Posted: 24 Jul 2018 07:37pm
Okay awesome, I'll definitely check that out. Thanks guys
lburners
# Posted: 31 Jul 2018 08:43pm
You should check the town website. Look for areas with no building zoning. There is some state rules on seasonal cabins that are pretty lax unless you get into septic and wells. Any structures that will be a primary dwelling get into some pretty standard regulations where you will need to apply for permits.
turkeyboyslim
# Posted: 31 Jan 2019 02:48pm
I just moved to VT a few months ago, I am planning on buying land in a town without zoning. I have a list of towns with no zoning. Therefore you only have to adhere to state-zoning. I called the state permit specialist and he was very kind, he pretty much told me I could build a cabin or home (for me and my family, not for commercial use) and harvest solar energy and use grey-water filtration all without permits. He informed me that a permit is required for septic and wells, and for any driveway more than 1 acre.
I will post the list of unzoned towns when I get home where I have the list.
turkeyboyslim
# Posted: 1 Feb 2019 08:44pm - Edited by: turkeyboyslim
My list so far of towns in VT with no zoning: Albany Worcester Orange Roxbury Williamstown Walden wheelock Coventry Brownington Lunenburg Royalton Vernon Middletown Springs Newark Charleston
turkeyboyslim
# Posted: 8 Apr 2019 11:51am
Additional Findings of towns without zoning: Averill Eden Chelsea Glover Holland Sutton Irasburg Brighton Topsham Johnson
- - Always double check with the town before making a purchase or decision, this is just a list I've put together based on the research I've done. Of course I would call the town before making a purchase to verify the zoning information. It should also be noted MOST of these towns are located in Central/Northern VT as this is the area I am most interested in.
# Posted: 10 Apr 2019 12:13pm
No zoning does not mean no building inspections and no codes. Know the difference before you shell out any money. Call the local county/town building inspector and ask questions.
My property has no zoning but still dosnt allow a standard outhouse, no where in NY does. Yet they allow a shed to be built and a small generator shed before i pull a permit for a cabin. Framing, plumbing, electrical all need to be inspected still.
turkeyboyslim
# Posted: 12 Apr 2019 02:33pm
No town zoning means you have to adhere to state zoning, at-least here in VT. Almost all town without zoning I've seen don't have a building department and can't issue permits. You have to go to state level for that. However I do agree double or triple check before shelling out money. Last I talked to the state permit specialist he said a composting toilet was okay (along as it wasn't near body of water and so forth) and a greywater Filtration system is allowed without permits. So I would think an outhouse would be okay, but I'd have to double check. Either way the town doesn't have an inspection crew so I doubt they would really do anything if your acres deep into the woodland, acres away from neighbors.
# Posted: 14 Apr 2019 08:47am
Your county may be the one issueing the permits then. I wouldnt bank on the fact that an outhouse may be legal. Find out for sure.
No where in NYS is an standard outhouse legal. I believe you can build one over a septic tank with no outlet and have it pumped. Its a option, but at that point just put a real septic in and i door plumbing.
turkeyboyslim
# Posted: 15 Apr 2019 12:42pm
For example this town requires you to go to state for permits:
https://charlestonvt.org/town-office/permitsformsapplications/
turkeyboyslim
# Posted: 17 May 2019 02:45pm - Edited by: turkeyboyslim
You're right though about outhouses not being legal. Even if the town has no zoning and doesn't issue permits if you want to claim your property as a full time residence you need Septic and a water source which require permits. If you're having a camp with less then 180 days of use a year they don't require anything.
