# Posted: 28 Sep 2016 09:01am
Hi folks,
As most are aware I am a "Foam Fanatic" and use various types of foams in my construction projects. The usual suspects include EPS, XPS, Poly-Iso etc... Just can't beat it ! As a result the use of Spray Foam is an essential component to fill in gaps, cracks etc as well as bonding layers. (no matter how tight you go, there is always tiny gaps, unless your building SIPS and even then)
Well LESSON LEARNED ! I have used commercial foam guns for many years and my last one died a while back after many years of good service... It was all brass and a breeze to use & clean...
So off I go top buy a replacement gun and shocked at how expensive they got.. I decided that as I no longer need the Pro Commercial HD gun I wasn't dropping over a C Note on it... I went with the Mid-Range gun and bought a AdFast Heavygun-TF like this:
DON'T BUY THIS ! It comes with very thin plastic "disposable tips" which when the foam & it's solvents hit the plastic tubes, they soften up and like to blow off... There ARE NO REPLACEMENT TIPS AVAILABLE ! Imagine That one ! Make a tool that uses disposable bit and offer no replacement bits ! HeadSlap Moment for that company ! The Cleaner Solvent - well, it cleans the gun & foam but that plastic - I'll leave it to your imagination...
Well after some furtling around and looking at OTHER BRANDS, I found a LePage gun which is all Brass including the needle tip which runs at $90... More poking about I found the DOW Pro-14 Gun at Homedepot for $69 and not only does it have all brass construction including the needle tip but also has tip sleeves that won't dissolve or soften with available replacement should you need them.
You can see the subtle differences that make the grade... If you see a product that has "replaceable / disposable bits" make sure you can get the bits when needed..
Hope it helps someone to avoid wasting money and using Drunken Sailor Talk...
Have a Great Day !
