Small Cabin Forum / Properties / Heater
Shadyacres
# Posted: 6 Oct 2014 09:56pm
Does anyone have suggestions for a reliable heater for my basement that I can set thermostat at 40 degrees ?
# Posted: 6 Oct 2014 10:50pm
What fuel sources are available? What would you prefer to use? How large is the space to be heated? Any insulation in/on the basement walls? Climate?
Shadyacres
# Posted: 6 Oct 2014 11:21pm
I have a 20 X 30 superior basement wall with R-23 insulation. I don't think it will take a lot of heat. I was thinking of going with propane but didn't know if electric would be more dependable but not sure which would be more economical.
# Posted: 7 Oct 2014 12:33am - Edited by: MtnDon
Download this spreadsheet calculator....
Heating Fuel Cost Comparison Calculator
# Posted: 7 Oct 2014 12:45am
A fuel burning heater will need an exhaust vent and an air intake. Above ground a direct vent wall heater might be usable if you can cut through the wall.
Nice thing about electric is you just need wires (and a service panel that has the capacity)..
Shadyacres
# Posted: 7 Oct 2014 05:47am
Thanks MtnDon , I have the option to do either. I too gave electric a nod for just that reason. I may opt to try electric and see what the bill is each month , I think I have a thermostat and a couple heat units laying around.
itsals1
# Posted: 7 Oct 2014 07:11am
Shadyacres,
We have a cabin in northern WI and have a utility room that has electric baseboard heater. Ours works great, it does have a built in thermastat which we keep at 42*. Our most expensive bill was this last winter which was around $50-$60. Considering it costs us $35.00 a month just for the meter. The Utility room is 6'x7'6" and is 2x4 construction R-13 walls,with 2" foam board we use to block the door to help retain the heat.
Travis
# Posted: 7 Oct 2014 10:34am
If you are just trying to keep pipes from freezing, maybe electric tape on the pipes is cheaper than heating the whole room?
Shadyacres
# Posted: 10 Mar 2015 05:33pm
My electric heater is working great , it has been a very cold winter and my electric bill is about $ 25 to $ 30 each month and I think it was about that price without electric heater so I am only spending a few dollars a month to protect my water tank, water heater and traps.
Shadyacres
# Posted: 10 Mar 2015 05:34pm
uberjason
# Posted: 29 Oct 2017 10:00am
Milkhouse heater or I prefer the oil radiant heater to protect pipes. Oil heaters are sealed, so if they fall over no harm no fowl. Electric heaters like the milk house heaters use a heating coil. These are great until they get dust on them in the summer months, you have to remove an electric heater at first use of the season and run them outdoors to burn off the crap that can catch on fire.
