# Posted: 10 Sep 2020 09:22am - Edited by: Nobadays
The procedure I used gotten from a small engine repair shop guy.... Toyota will likely have some good info too. I have about 600 hours on it and it runs great!
Using regular 30w motor oil - run for 1 hour at idle/eco mode, then drain the oil let it cool down and put fresh regular 30w motor oil in it.
Run for 4 hours alternating between eco/standard mode, plus start putting loads to it off and on for a few minutes at a time - nothing too heavy, stay under that 75% - I used a hair dryer, turning it on for 3-5 minutes then turning it off. Sometimes when not using the hair dryer let it idle to eco, others the standard idle. Probably turned the hair dryer on and of 6-8 times each hour. (I babysat this thing all afternoon. )
After this 4 hour run I again changed the oil but this time refilled it with full synthetic 5/30w, this was winter, normally I use 10/40w full synthetic in the summer. I did not exceed the 75% load for the first 100 hours.
EDIT: Brett is right oil is cheap... I didn't change mine as often as he suggests but that is likely good advice.
I will give you one heads up on this generator. The vent for the gas tank is hooked to a charcoal canister that then feeds these fumes back into the carburetor. If you over fill the fuel tank... which will happen... the excess fuel floods this charcoal canister. What happens next is this fuel/air mixture is injected into the carburetor making the engine run extremely rich, fouling the plug and just generally running like crap or just dieing. There are YouTube videos out there showing how to remove this canister... or if you just look you can likely figure it out. I ran overvalued year without flooding the canister but when I did, I could not get the engine to run well, continually dieing, sputtering. Took out the canister and now it runs great.
