Small Cabin Forum / Off-Grid Living / Cabin Water System
GreyValley7
# Posted: 28 Aug 2020 07:32pm
Hi All,
I have a remote cabin in the woods with a drilled well but no electricity. I’m hoping you all may provide a few ideas to get water from the well into the cabin for dishes/propane shower? For reference the well is about 30’ away on the downhill side
Thanks for the reply’s
Irrigation Guy
# Posted: 28 Aug 2020 08:19pm
Is this just a casing? Can you install a pump and run with generator? Do you want automatic? Do you want it piped into the house?
# Posted: 28 Aug 2020 08:50pm - Edited by: ICC
and how deep is the hole? and the depth to static level?
GreyValley7
# Posted: 28 Aug 2020 09:37pm
Thanks for the reply’s. I would rather not run/listen to a generator if possible? I ultimately would like it pumped into the house to use for dishes/propane shower etc. I am not positive on the well depth, but It is a casing that originally had a hand pump connected to it. The static water level is about 15 ft below ground
# Posted: 28 Aug 2020 09:53pm
IF you had water in the house, with no electricity, how do you imagine getting it to the sink to do dishes or the shower?
# Posted: 28 Aug 2020 10:01pm
Part time or full time use?
I would probably install a two to three hundred gallon storage tank in, under or beside the cabin. Use a generator to power a shallow well pump to fill the tank as needed. Use a shurflo 12 vdc RV pump to distribute water in the cabin, powered off a battery with a solar charger. Something like that if it was part time use.
Irrigation Guy
# Posted: 28 Aug 2020 10:15pm
Depending on your usage you might be able to install a large pressure tank 80 gallons or so which would give you 40 gallons +/- of pressurized storage. You would likely only need to run the generator once a day to fill the tank. When I am at my place alone the pump comes on once a day and I have a 50 gallon tank, so about 20-25 gallon storage.
