Small Cabin Forum / Off-Grid Living / Water always running in my well
Jcotrel1
# Posted: 30 May 2020 07:06am
I constantly hear running water in my well. Even when the pump is turned off at the breaker. I checked the neighbor's. His is quiet. Any thoughts on why this is?
Irrigation Guy
# Posted: 30 May 2020 07:50am
If your well is drilled into rock you probably hear water entering the bore from above the static water level from a crack in the rock, probably not an issue.
If you have a cased well all the way down you have a hole in the casing where water is entering above the static’s level which is not good. This could cause sand or soil to enter your well.
