socceronly
# Posted: 29 Aug 2019 12:04pm
Any thoughts here?
If the stove has a rear vent, are there any concerns with running the pipe up the chimney?
Do you insulate/block the air flow around the pipe inside the chimney with something heat resistant / fireproof?
What can go wrong....
# Posted: 29 Aug 2019 04:54pm
We're talking a masonry chimney? There are stainless steel liners made for connecting to a wood stove used as an insert in a old fireplace.
beachman
# Posted: 5 Sep 2019 10:30am
I installed a wood stove this way with a stainless liner and have not had any problems. The masonry chimney had a good clay liner. The stove works great. Did not bock airflow around the pipe with anything but use it hardly ever in winter as place is not insulated.
# Posted: 5 Sep 2019 10:45am
I would suggest that you check out if you’re woodstove is an airtight stove. They have a damper that controls air to the firebox or fire. If you have an open draft from the fireplace that can draw air it could effect how your wood stove works.
# Posted: 6 Sep 2019 08:40am
Any one that uses a wood stove i highly recommend you put an outside air kit on it. It pulls in outside air for combustion and not from the living space.
jos_davies
# Posted: 8 Oct 2019 05:07am
The chimney and fireplace at my cabin had deteriorated quite a bit. The metal liner and heatilator conduits in the fireplace were rusted and the masonry chimney liner and blockwork was crumbling in places.
I repaired the blockwork, installed a stainless steel flue liner, blocked the heatilator vents with stonework and installed a wood burning insert. I can get an 8 to 9 hour burn with hardwood if I manage the insert correctly.
I also highly recommend getting a blower. It puts out much more heat into the house.
