Small Cabin Forum / Off-Grid Living / Off the grid garden shed
swordfish
# Posted: 24 May 2019 03:36pm
Hello! Very first post to this forum, I appreciate whatever feedback I could get from the community!
I am wrapping up the designing phase of my lighting and electrical setup for my new 10x16 garden shed.
I would like to run my plan by you guys to makes sure it makes sense and I don't burn the thing down.
I started on the premise that a single 100w solar panel would be sufficient for my needs. I also have a 15 amp solar charge controller, and finally, I have already affixed (but not wired) 8 18w (rated by the manufacturer at 2.7 amps each) LED lights for interior lighting (I have very little natural light that comes in, and will be using the shed as a "workshop and garage" for a ride-on mower).
The entire electrical installation will be run on 12v DC. I don't plan on having an inverter, although a small one may become an option down the road.
Considering my 100w panel and 15 amp charger, would a 30 Ah battery be a reasonable choice for this setup?
Second, would 14 AWG CL2-rated speaker wire (one circuit per 18w light head) be an appropriate wire to use for the lighting portion of the circuit? Each run of wire would be within 10-15 feet of my distribution panel.
If you need more details about my plan, don't hesitate, and once again, thanks in advance for your help!
# Posted: 25 May 2019 09:49am
Your 100w panel will give you 8 amps at 12v. Roughly.
Your 8 light bulbs will draw 150w (give or take). That's 12 amps at 12v and would drain a 30 amp battery in a bit more than an hour.
I would go more like 200w and 1kwh of usable storage.
Course, I'd also go 24v or 48 to make my life easier.
Good luck.
swordfish
# Posted: 25 May 2019 04:03pm - Edited by: swordfish
Alright! Thanks for the insight.
With my limited knowledge of electricity, and by looking at my equipment I already have (solar panel, solar charge controller, and my LEDs), I don't believe it would be possible to change to a 24v system? If it is actually possible, how would I go about it? I know I need a 24v battery, but how would I step down voltage for my 12v lights, and step it up for my 12v panel and charger?
[EDIT] I just checked my charge controller - 15 amp, 12v or 24v... so I imagine it steps up the voltage to charge a 24v battery...
And I failed to mention, not all 8 lights are going to be on at the same time. I plan on splitting it to 4 banks of 2 lights, independently controlled, considering my needs.
I will keep looking around for answers as well, but I thought I would bounce the question by you as well.
# Posted: 26 May 2019 08:55am
How far away is grid power? If its not far it may be worth the expense to use than and not mess with solar.
Have you use a "useable solar by zip code calculator"? It basicly told me my area is not worth the hastle of solar..and no solar isnt free.
swordfish
# Posted: 26 May 2019 08:57am - Edited by: swordfish
Not worth the several hundred dollars to connect to power grid, just to light up a shed... I'm about 125' from the house.. And, I'm in Canada, so I don't know if zip code calculator would work?
# Posted: 26 May 2019 09:12am
If you're in Canada you're good to go.
I can't believe there's anywhere that can't benefit from solar. But. Meh.
Here's my shopping list for my "shed" kits. 1 lithium battery. 1kw. 24v. 300. One solar panel. Used. 260w. 120. One victron mppt 75/15 (I can put another panel on). 155. Then add bits and bobs as you like. 50 for wire what not. 24v distribution panel for lights etc. 12-36. Inverter? 250w. 150?
So for 6-800 I can charge stuff. Run lights. Play music. Spend 255 on the inverter and put a small fridge down at the water. And this equipment should be good for 25 years. So call it 30/yr? All prices cad.
Plus no c02. No maintenance other than cleaning the panel. No noise.
swordfish
# Posted: 26 May 2019 09:34am
Considering that my lights (and some other things I'm thinking of adding on later) are 12v, would it be feasible to use my 24v charger and battery, but to use a 24v to 12v buck converter to supply my distribution panel?
# Posted: 26 May 2019 11:26am
What kind of work are you doing that you only need lights.
swordfish
# Posted: 26 May 2019 12:50pm
It's basically a garden shed, that will also serve as a space where I can do maintenance work on my John Deere lawn tractor (I will be taking it apart to restore and repaint it). So good lighting is a must, but I also want to have the option of having a small inverter to power a small handheld sander.
# Posted: 28 May 2019 08:08am
Run an extension cord out there. Your really just looking for temp power. For maintence use a headlamp and open the doors for light. Solar is going to be very expensive for a once a season need.
