offgrididaho
# Posted: 16 May 2019 09:12pm
Looks like new product line for them, they sure hit a nice price point compared to Victron: https://www.renogy.com/products/inverters/inverter-chargers
That said, personally I've been a little underwhelmed with my Renogy products in the past, and will be interesting to see how these are received and how long lived they are.
spoofer
# Posted: 17 May 2019 01:38pm
I have a renogy 100 watt system at my shack. When twilight comes my 12 volt lights flicker until its totally dark outside. I think my renogy charge controller is the culprit of this. Otherwise my system is trouble free. The 30 minutes of flickering lights is getting on my nerves enough that I actually lit a oil lamp until it was totally dark out. Then my 12v, 10 watt led lights shine bright. Any idea whats causing this?...
offgrididaho
# Posted: 18 May 2019 01:01am
My guess would be voltage varying above and below the cutoff point to send amps from charge controller to the batteries... when the controller is sending some amps (even very few) to the batteries then the lights get brighter because there's higher voltage in the system, when the amps cut off from the controller then there's lower overall voltage in the system?
Is this an MPPT or PWM controller?
spoofer
# Posted: 19 May 2019 03:40pm
mppt
