Kamn
# Posted: 30 Jan 2019 05:37pm
wondering what size and make of inverters people are using for their off grid places? When I say large, Im talking 4kw and up.
# Posted: 30 Jan 2019 06:25pm
Schneider Electric Conext XW+ 6848 Inverter & Charger, 6.8 kW, 48 volt
Atlincabin
# Posted: 30 Jan 2019 06:31pm
Magnum, 4 kW inverter/charger. Working perfectly for the last 6 summers. 24V system.
# Posted: 30 Jan 2019 08:43pm
Building 2: one's a schneider xw+ 5548. The other's a dual 8kw Victron (16kw). I have 2 5kw in the field running now. Both are for smaller home systems and both regret the high operating overhead. The bigger the inverter the faster the idle load seems to rise. I have, by contrast, a mere 3kw on my home system.
Remember, when sizing your inverter: most inverters will cheerfully run 2x the capacity of the inverter on surge. So build your inverter to your loads, not your surge.
Wilbour
# Posted: 31 Jan 2019 09:21pm
Quoting: creeky build your inverter to your loads, not your surge.
But as creeky and I found out, you cannot ignore the surge entirely. My 60W fridge would trip a 300w inverter because the surge was over 700w. My 500w inverter handles this surge with ease.
# Posted: 1 Feb 2019 11:14am
Quoting: Wilbour you cannot ignore the surge entirely
Kamn
# Posted: 1 Feb 2019 03:15pm
Thank you all for your input.
# Posted: 11 Feb 2019 08:54pm
I use only a 1000 surge to 2000 pure sine inverter with soft start for my fridge, problem with the inverter is it idles at 1.75 amps otherwise good, still need new batteries hopefully in spring.
