# Posted: 9 Dec 2018 01:34pm
Hi all, a friend of mine is looking for ideas about the best low surge well pump. Something with soft start it would seem. I am far from knowledgeable on this topic.
What well pump are you using? Are you using solar?
He's got a good inverter. But he's looking to downsize it (and that 40w/hr idle draw!) and the drawback is that to do so he has to replace his well pump. Ideas?
He's hoping for cheap.
Nate R
# Posted: 9 Dec 2018 02:41pm
Grundfos has some 2 wire 115v 1/2 HP pumps that I've seen others use from inverters adn small generators. IIRC, the 5 GPM SQ pump uses 4-5 Amps running, and I think a startup MAX Of 12 Amps. I THINK.
Grundfos has a whole line of pumps now for renewables, too. SQE, I think.
# Posted: 9 Dec 2018 05:01pm
I second the Grundfos pump. I and a neighbor rancher friend have their SQFlex series pumps running off solar panels, some with batteries some without. They have both helical gear pumps for depth and centrifugal for higher flow.
# Posted: 9 Dec 2018 06:12pm
This article may help.
http://solarhomestead.com/best-off-grid-well-pumps/
beachman
# Posted: 10 Dec 2018 09:11am
Rockies - great link for the water pumps. I have two manual ones that I am thinking of converting and have a small solar set up as well as a good-size generator. I like the idea of being able to fill my loft tank for the bathroom water supply with a small electric pump instead of the Guzzler pump currently used. It takes about 180 pumps to fill it (35gals) and I am not getting any younger. I was looking at jet pumps but after reading the article, I would likely go with a piston type pump.
