cspot
# Posted: 3 Sep 2018 09:39pm
Right now I have a Champion 2000 W Inverter Generator that runs on gas. I have noticed though that there are generators now coming out that run on propane or can run on either. Anyone ever use one of these? Just thinking since I am putting in a bigger propane setup at camp, I may go propane if my Generator ever craps out. I wouldn't have to worry about running out of fuel.
# Posted: 3 Sep 2018 10:22pm
Google tri fuel conversion kits. You may find one for your genny.
# Posted: 4 Sep 2018 08:35am
Another advantage of propane power is clean oil for a lot longer and no gummed up carbs.
# Posted: 4 Sep 2018 10:00am
I have two propane generators, both coincidentally given to me. The manual for the Onan says consumption is:
GAS .4 gph no load .7 half load 1.3 full load
PROPANE 2.1 lbs. hr no load 4.1 half load 6.6 full load
Dave1986
# Posted: 5 Feb 2019 01:56am
Yes, they are very useful if you choose the model you need. If you still consider buying a good propane generator, get helpful info on it on https://lawngardentop.com/best-power-generator/best-propane-generators. All pros and cons of every model are explained in a proper way, there is no use to retell it here again.
