Small Cabin Forum / Off-Grid Living / Combining batteries of different ages?
WetCoastCabin
# Posted: 19 Aug 2018 01:39pm
Hi there! I bought 8 6V 200amp hr Costco deep cycle batteries 2 months ago, and need to buy 8 more. They have been hooked up to be a 12V battery bank and charged via a 40amp solar charge controller hooked up to 2 x 250watt panels. I hooked it up to get started and learn about solar, so I've only actually used the batteries maybe 4 times in the last two months. I want to move to a 48v system. My main question is what type of battery do you recommend I buy and would it be ok to combine my original 8 batteries with the 8 new ones? Please say yes. Worried that even adding batteries even after 1 day of use removes the ability to combine batteries of different ages? How strict is the battery combining requirement they are the same age? Thanks in advance!
# Posted: 19 Aug 2018 07:03pm
It’s not ideal but sounds like yours are new enough that it won’t be a problem. I’d do it. That being said that sounds like an awfully big battery bank compared to your solar. Do you really need that much capacity?
WetCoastCabin
# Posted: 19 Aug 2018 07:50pm
Thanks FishHog! I have 14 more 270watt panels I'm going to set up soon. Roughly a 4k system. I need lots of juice to run two well pumps (one in the well one in a storage tank) that are 1/2 horsepower pumps pulling 3000 watts on startup and 240volt. I'm also trying to source a good inverter for this setup. Researching AIMS, MagnaSine and Schnieder and would love any advice on that front.
# Posted: 20 Aug 2018 09:28am
Ok that makes sense now. I’ve been researching inverters although smaller for my camper van and am heavily leaning towards the aims but I don’t think you will go wrong with any of those
ILFE
# Posted: 20 Aug 2018 01:20pm
2 strings of 48 volts batteries will be much better than 4 strings of 12 volts batteries. And, two months won't be much of an issue.
Atlincabin
# Posted: 20 Aug 2018 04:00pm
We have a Magnasine inverter (4kW) at our cabin. 5 summers full-time there and it has worked flawlessly. I run most everything I need from it - water pump, table saw, washing machine, and even the occasional light bulb! Just a data point for you.
