# Posted: 22 Dec 2017 10:28pm
Running electrical 100 ft will be the least of your problems. Not really far enough to worry about voltage drop but it can’t hurt to upsize your wire.
Size of the wire you use will depend entirely on how much amperage you produce with your generator. Saw pics of a simple water wheel connected to an auto alternator- looked viable. For more power a large water wheel and sluice would be effective, but a lot of work. In larger installations they dam the creek upstream, run a pipe down from there to a location with enough vertical drop and connect to a pelton wheel and generator. All depends how much you want/need
