Willie1959
# Posted: 23 Aug 2017 09:04am
Propane Consumption Rate First thing to keep in mind is that the estimate given by the manufacturer for the gasoline run time can be used for propane also because it is just that; an estimate or guess. Propane only has about 10% less Btu content than gasoline gallon-to-gallon, so the estimate used by Yamaha for gasoline consumption will be very close for propane if not exact. The biggest mistake most "experts" make in opinionating that a propane or natural gas generator will lose power is based solely on these figures and not on any data they personally have. When figuring power output of any fuel, the size of the engine has to be a significant factor of the total equation. For instance, comparing a vehicle with a V8 engine to a generator with an 11hp generator attached can not be calculated the same. The characteristics of the fuels and how they mix with air, how far the piston is in relation the gasoline float bowl effects the power derived from the fuel among many other things. To presume that just because the btu content is less, it is less powerful, is erroneous. But for those that want even more information we now offer some basic factors, round numbers and some good estimates to see how run time values of propane cylinders can be worked out: BASIC FACTORS It requires 2 horsepower to produce 1000 watts of energy per hour under load Under load, each horsepower consumes 10,000 BTU per hour Propane contains 92,000 BTU per gallon Propane weighs 4.2 pounds per gallon Cylinders are rated by their weight capacity of propane Bulk tanks are rated by gallon Cylinder Capacities in Gallons and BTU's Size Gallon Capacity Total BTU Capacity 20# 4.8 441,600 30# 7.1 653,200 40# 9.5 874,000 60# 14.3 1,315,600 100# 23.8 2,189,600 200# 47.2 4,342,400 420# 99.1 9,117,200 Using these factors we can arrive at run times based on average load for any generator. For instance: How long would a 5000 Watt Generator with a 10 HP engine at 50% load run on a 20# propane cylinder? 10hp at 50% load would be using 5 horse power to generate 2500 watts of energy. 5hp x 10,000 btu would consume 50,000 btu per hour. Using a 20# cylinder that produces 441,600 total btu, the engine consuming 50,000 btu per hour would run for about 8.8 hours.
BTU consumption chart based on generator/engine size and load Generator Wattage Engine Horsepower Full Load 75% Load 50% Load 1850 3.5 35,000 26,250 17,500 4000 8 80,000 60,000 40,000 5000 10 100,000 75,000 50,000 7500 15.5 155,000 116,250 77,500 8000 16 160,000 120,000 80,000 10,000 20 200,000 150,000 100,000 12,000 24 240,000 180,000 120,000 Many people want to know what size cylinders they need based on their engine size. Here are some real conservative estimates of the vaporization rate of various size cylinders based on the outside temperature. Vaporization Rates of Cylinders Output in BTU's per hour - Vertical Cylinder 25% full - Minimum Cylinder Pressure 10 PSI Cylinder Size Outside Temperature 20 30 40 100 200 420
+60F 24,000 32,000 40,100 79,700 125,900 185,500 +50F 21,200 28,300 35,500 70,600 111,500 164,300 +40F 18,450 24,700 31,000 61,500 97,200 143,100 +30F 15,700 21,000 26,400 52,400 82,800 122,000 +20F 13,000 17,300 21,800 43,300 68,400 100,700 +10F 10,250 13,700 17,200 34,200 54,000 79,500 0 7,500 10,000 12,600 25,000 39,500 58,300 -10F 4,780 6,400 8,000 16,000 25,300 37,100 -20F 2,050 2,700 3,400 6,800 10,700 15,900 For the physical properties of each cylinder, click on the "Cylinder Size" above. What does all this mean? Well, if you went exactly by the chart, you would need a 420# cylinder to run a 14hp engine if it was 25% full and 40 degrees outside and keep a minimum of 10 psi in the cylinder. This is a worse case scenario. For instance, when a 20# cylinder is full it can run a 16hp engine for quite some time in 40 degree weather before there will be any freezing problem. But if you wanted to use up all the gas in a cylinder, it would have to be sized according to the chart. Here is why. Propane is stored as a liquid under pressure and boils to produce a vapor that is drawn off at the top for the engine to use as the fuel. Because propane boils at -44° (below zero), the gas will freeze if it can not absorb enough ambient heat to compensate for the boiling process. The bigger the cylinder is compared to the amount of load, the warmer it is outside, the warmer the cylinder is kept, all are a determining factor in the likelihood of a cylinder freezing up. If a sweat or frost line forms around the cylinder at the level of the fuel, this is a telltale sign that the cylinder over worked and is in the process of freeze up. If the gas does freeze, it will stop producing vapor and the pressure inside the cylinder will drop to as low as zero psi which will cause the engine to stop running. To compensate for an undersize cylinder, two cylinders can be tied together using a tee check and pigtails. Some customers set the cylinder near the exhaust of the engine to help keep the cylinder warm and have no problem using smaller tanks on bigger engines. This practice needs to be carefully monitored so that the cylinder does not overheat and cause the relief valve to check off.
Typical propane fuel consumption for a 2000 watt inverter generator A liter of propane is 1.1 pounds so propane at $1 per pound = .90c per liter Propane at .65c per pound typical for 100lbs cylinder =.585 per liter 50% load 800 watts = .42 lbs per hour or .37 liters per hour 75% load 1200 watts = .86 lbs per hour or .73 liters per hour 100% load 1600 watts = 1.25 lbs per hour or 1.125 liters per hour
