Small Cabin Forum / Off-Grid Living / Rickant generators
Rickant
# Posted: 13 May 2017 06:47pm
4. How would a generator work if we wanted it as a backup option to feed the cabin? Is that a costly backup? Presumably I would just use I to charge the batteries as needed or is it something that would also be able to connect to the cabin electrical system?
Atlincabin
# Posted: 13 May 2017 08:07pm
Generator can easily be wired in to charge batteries. If you go with an inverter, they typically have an input side for non-solar power, such as a generator or grid power. Simple wiring, almost plug and play.
Personally, I've lived with both 12V power systems (i.e., lights etc. are all 12V - this was some 30+ years ago) and the newer systems with high-quality inverters to run everything on 110V. I much prefer the 110V since you don't have to purchase a bunch of (typically expensive) 12V things, you can just use "normal" appliances, power tools, light bulbs etc. Yes, you lose a slight bit of power, but solar panels are very cheap these days so just add an extra panel for $200 or so, and it will more than cover the power losses of the inverter system.
Again, my two cents.
# Posted: 13 May 2017 08:23pm
http://thewirecutter.com/reviews/best-portable-generator/
