rmak
# Posted: 31 Aug 2016 03:32pm
I finally found a solar pond aerator that I could afford. It came with two small solar panels, 17 X 26 inch size. I know there are advantages of wiring the panels either way, series or parallel, but I don't understand the benefits of each. Could someone explain it to me? The aerator is direct hook up, no batteries, dc and only pumps when the sun shines.
A final question/gripe. Why are these panels always blue? They stick out like a sore thumb! Couldn't they be painted a nice green color to blend in more?
# Posted: 31 Aug 2016 04:11pm
I would wire them according to the instructions for the pump .Ether 12 or 24 volts the pump is likly one or the other..IF it says 24 you can use smaller and longer wire.I have one also ,no batteries.
# Posted: 31 Aug 2016 05:45pm
Yes, match the voltage to the pump. Series connection increases voltage (doubles if both panels are the same) That could burn out the pump.
Color: that is just the way it is. Some bluer than others. Some blacker.
# Posted: 31 Aug 2016 08:47pm
Don't paint your panels. They won't work
rmak
# Posted: 31 Aug 2016 11:28pm
Quoting: bldginsp Don't paint your panels. They won't work eh..yeah. I was asking why they couldn't be manufactured to fit better into the environment. I believe light absorption is contingent on value (a scale from light to dark) and not on a specific color. So I don't think that's the issue. I can't think of a reason they have to look so industrial. They really don't look that great if someone is trying to create and spend time in a natural setting.
# Posted: 31 Aug 2016 11:47pm
https://www.quora.com/Why-are-solar-panels-blue
rmak
# Posted: 1 Sep 2016 09:20am
Thanks, MtnDon. I would have actually preferred black.
rmak
# Posted: 1 Sep 2016 09:25am
Oh well. It seems I'm late again coming up with a million dollar idea...
https://www.yahoo.com/news/green-roof-solar-panels-change-colors-175915555.html
