Small Cabin Forum / Off-Grid Living / Care of 12v water pumps
lawnjocky
# Posted: 14 Aug 2016 02:32pm
I use a 12 v RV water pressure pump to boost the pressure for my on demand hot water heater. I cracked the last one when I did not get all the water out and it froze. I am looking for advice as to what I should do to prep the pump for non use over the cold months. I have heard that there are products that can be put into the system before prolonged non use that can extend the life of the pump. Any advice on this is appreciated.
# Posted: 14 Aug 2016 03:41pm
RV antifreeze.
# Posted: 14 Aug 2016 09:20pm - Edited by: bldginsp
Yes- RV antifreeze- propylene glycol. It is non- toxic and inexpensive. I pour it into my toilet shower and sink before winter. DONT use any other type of antifreeze- they are all toxic and bad for septic systems. RV antifreeze is fine in septic systems.
You'll probably have to work up some kind of system which ensures that the antifreeze gets to the pump- without putting antifreeze in your whole storage tank, which would dilute it too much.
You'll find numerous products on the market called RV antifreeze, but the cheapest way to buy it is from food service suppliers- around 20 bucks a gallon for concentrate. When diluted 4 parts water to 1 part antifreeze it prevents bursting down to -50F. The water still freezes at low temps, but it just makes this slushy goo, and doesn't freeze into a solid block which is what busts the pipes.
old243
# Posted: 15 Aug 2016 08:58am
In our RV we isolate the pump, it has hose disconnects on the plumbing. Then turn the pump on for a couple of seconds to clear any water.. To winterize the camper system , we purge all the lines with air. Made a pressure reducer fitting that goes on the water intake, so as not to damage plumbing lines. Used to use rv antifreeze, found the taste remained , for a while in the spring. Also use rv anti freeze in all sink traps and toilet. old243
# Posted: 15 Aug 2016 11:33am
I built sharkfit or similar links into my system. I turn off power. Unplug the various devices/lines. RV antifreeze also worked well in the past. Cheap at the big boxes.
lawnjocky
# Posted: 16 Aug 2016 08:51pm
Thanks, I will try some out.
