# Posted: 11 Jan 2016 01:44pm
Every time I have to recharge the batteries by generator the next day is ALWAYS sunny....anyone else have such luck?
Also, when heating your cabin, don't forget to crack a couple windows, makes it heat much faster and more evenly.
Been torn as to wether or not to double battery capacity but with generator recharge required only occasionally over just two months out of the year it's a hard sell.
Going to remove the wood stove since I don't use it any more and have been buying fire logs to keep the stove warm so It isn't a cold spot in the cabin....so out it goes.
# Posted: 17 Jan 2016 12:03am
Quoting: groingo Also, when heating your cabin, don't forget to crack a couple windows, makes it heat much faster and more evenly.
Ok, I tried that, I took a baseball bat and cracked several windows. Then, I figured, it would heat even faster if I cracked more, so I did. But, the cabin got cold all of a sudden. What did I do wrong?
pizzadude
# Posted: 17 Jan 2016 01:38am - Edited by: pizzadude
Quoting: bldginsp What did I do wrong? Don't say you forgot to crack the door That would just be silly ..
# Posted: 17 Jan 2016 03:13pm
Wrong bat, you need a 32 incher.
