Eva91
# Posted: 2 Nov 2015 12:32pm
I am in the process of building a 16 x16 cabin. Actually, the frame is done, just needs siding. Will be insulating and doing the floor and walls throughout the winter, snow and temperature permits.
I've got quite a bit figured out, as it is completely off grid since the nearest power pole is 2 miles away and natural gas line is another mile, but the heating is making me scratch my head. I'm heating with wood. no problem. However, I am away from home at work for approx. 9 hours a day, 5 days a week. How do I keep my cabin remotely warm so nothing freezes while I am away? There will be no one to throw a log on while I am gone. I'm looking for a....cheaper route to go to take the chill off. What is a good little heater? Propane?
I will eventually be purchasing solar panels and a generator, but for now, I need to figure everything out BEFORE next winter since it may be my first in it.
Thanks!
# Posted: 2 Nov 2015 03:33pm - Edited by: groingo
No brainer, Propane.
# Posted: 2 Nov 2015 03:43pm
Is there propane delivery available?Quoting: groingo No brainer, Propane. I agree. There is tons of info on this forum about different types of heaters........vented/ nonvented etc.
# Posted: 2 Nov 2015 03:47pm
Just type in "heaters" in the search bar on the left. That will give you a lot of options/opinions.
# Posted: 2 Nov 2015 04:18pm
Some of the new wood stoves out there can run for 9hrs easy. All we have up here to burn is spruce and birch and folks can get 10-12hrs of burn time with a full load. If you have access to better (more BTUs) wood, you should be able to burn even longer between fills.
Blaze King is a popular brand of stove up here, but there are others.
AK Seabee
# Posted: 3 Nov 2015 02:07am
If the cabin is insulated nine hours away is not going to allow the cabin to freeze If you bank the stove before you leave. you should be ok.
If you want to stay away longer a direct vent propane heater is a good option off grid. I use an 18000 btu direct vent propane heater along with the wood stove. I am estimating at least 90 percent of the heat comes from the wood stove. The combination has worked well so far.
I am researching the ups and downs of using a Toyo stove with solar for the power source. The downside of propane is its reliabilify in the cold.
Topper
# Posted: 15 Nov 2015 03:46pm
Ak Seabee, Have you checked with RES, Renewable Energy Systems of Alaska?
Was talking with them at the home show this past spring, here in Fairbanks. They have a solar setup that will more than handle a Toyostove.
Their website shows an Anchorage store as well.
AK Seabee
# Posted: 15 Nov 2015 04:22pm
Good call Topper. I bought the solar system this fall but have not completed the install. I should have the install completed in the spring and test the Toyo after.
Topper
# Posted: 15 Nov 2015 05:06pm
Ak Seabee,
I'll be interested in knowing how your system works!
Both my son & I are considering this setup for our cabins.
Salesman said the system will handle both the Toyo & a small freezer, at the same time, with room left over for lights, &c.
Sure would like to replace the drip-oil heater! That supplements the woodstove...
FeelFree
# Posted: 8 Dec 2015 01:27am
You could always go with a ventless propane heater.
beachman
# Posted: 8 Dec 2015 06:32am
What kind of fuel does the Toyo burn? What is the power requirement if using solar? (Watts, Amps, etc...) Do you have to hook this thing up to a fuel source, or just fill it occasionally?
littlesalmon4
# Posted: 8 Dec 2015 11:30am
Toyo stoves burn Diesel or home heating fuel. I have a RSF princess wood stove. You can easily get a 9 hr burn out of it. Keep it simple use wood.
AK Seabee
# Posted: 8 Dec 2015 01:51pm
Beachman, the Toyo uses between 50 and 85 watts to operate however during ignition may spike from 500 to 600 watts. The specs say a modified sine wave inverter may work but recommend a pure sine wave inverter of greater than 500 watts. The fuel source is either kerosene or #1 fuel oil as littlesalmon stated. Fuel consumption is low and kerosene works well at -40 or lower.
Jebediah
# Posted: 17 Dec 2015 07:35am - Edited by: Jebediah
If your cabin is well insulated and you have an efficient wood stove 9 hours shouldn't be an issue. Propane vented heaters, with thermostat,(not cheap) easy to install with a consistent heat level. I have 2 empire dv-15's if I'm away for 2 days or more I will use them on the lowest temp setting. Ashley vented heaters come in an 8-11k btu model and are sold at Home depot.
