Small Cabin Forum / Off-Grid Living / Charge controller wattage question
# Posted: 1 Nov 2015 11:58am - Edited by: groingo
Which should I be more concerned about, how many amps I run through the controller or how many watts?
Here's the conundrum.....want to add two more 100 watt panels to my existing 400 watts but the controller shows max input at 360 watts yet max amperage at 30.
If I add 200 more watts that will give me 600 watts at 30 amps....the amperage is correct but the wattage would be near double what the controller is rated for.....do I add a second charge controller?
I have a feeling the wattage is meaningless and the amperage is what really counts.
# Posted: 1 Nov 2015 01:37pm - Edited by: DaveBell
360 W / 12V = 30A
The input watts and amps are correct.
(assuming 12V batteries)
You are supplying 400 watts into a 30 amp controller which is 3 amps too much already and maybe more without the 25% safety margin.
400 watts / 12V * 25% = controller size needed.
(400/12) * 8.33 = 42 Amp controller
600 watts / 12V * 25% = controller size needed.
(600/12) * 12.5V = 62.5 Amp controller
"do I add a second charge controller?"
You can if the controller has a port to connect to the second controller so one can be programmed as primary.
You could buy a 60 Amp controller calculating a 20% safety margin to keep things simple.
# Posted: 1 Nov 2015 05:12pm
If I could clarify a few things.
Groingo you are right amps is what a charge controller works with.
Voltage is important in that you must keep your panels lower than the limit (usually 100 or 150v). if you go over voltage you will fry your CC.
The CC takes the voltage and amps, and, in the case of an MPPT CC, turns it into the required voltage your battery pack needs to charge efficiently. Increasing Amps* as available. A PWM CC simply loses the extra amps* only providing the necessary voltage.
*if there is any extra power available from the panels of course.
So what voltage does my battery require in order to charge?
Your 12v Lead acid (LA) battery pack is most likely to charge at around 14.5v at 25C/75F. Some are a bit lower, some a bit higher. Lithium you would probably limit at 14.1-14.4.
600w / 14.5v = 40 amps. A typical 60 amp controller will handle 800w. Mine both have 1kw on them.
Now the more important stuff.
What kind of CC is it? Any modern good quality MPPT CC will happily "overpanel." And it's an excellent idea now that solar panel costs have dropped so much. During peak solar production you will see a message "current limiting." That would be your controller limiting the current to keep within the max amperage. It does not damage a good CC. But nor will it go over the amperage max.
Now is a good time to remember, 80-90% of your solar collecting day will not be prime time. Cloud, mist, morning, evening etc all reduce the amount of power your panels can create. (I have a neat story but I'll save it for another time).
Quoting: groingo
A second controller is an excellent idea. Here is a brief overview from morningstar how to parallel a second controller with 2 arrays.
In your case Groingo tho, you would probably be best served with a bigger controller. Sell the old one.
But to parallel controllers just plug them in. If you want to get fancy and buy a special doohickey so that you get a master / slave relationship. each to their own. there is no reason to though. you may see a slight imbalance without it. but in the big scheme of things. no worries.
hope this helps.
