# Posted: 7 Jul 2015 08:28pm
I'm not using that one, but mine is set up just the same way as that one. Mine will run on 12-36 VDC. This is for a livestock well and you should be able to do it without batteries, just solar. Unless you want to pump water at night. Notice the pipe from pump is only 1/2". Pay attention to total lift specs, this is feet above the static water line. I don't know how deep your well is. But you wan this info to make sure it will work. Deeper well pumps also mean deeper pockets too (spendy). Use a sock over the entire pump to keep it from ingesting sand etc.
