# Posted: 15 Apr 2015 08:04pm - Edited by: bldginsp
Reply Quote
Google 'well pump sizing' or 'choosing a well pump' and you'll find a bunch of sites. I've been looking into this too, but for a deep well not a cistern. You may not need a submersible pump since you are not pumping from deep. Matching pump size to the situation is critical and you need to factor in total head, pressure of the pressure tank, length and diameter of supply pipe etc. using the correct formulas. Usually for a house people pump at 10 gpm to pressure tank so I'm told, in a cabin you might be ok with 7. How far is the power source from the pump? Wire can get expensive, but you will probably use a smaller pump requiring smaller wire. You can hire a well service to do the whole thing for you but they'll charge you.
And you need to protect from freezing if that's an issue.
Good luck
