downcard11
# Posted: 6 Nov 2014 01:05pm
Anyone have any information on grey water systems, or a good place to find some more info on the net? It's one of the few things I've been trying to search where I can't find some good information. I know there are very simple systems and some more expensive. I will be building in Southern Vermont/The Berkshires, if that matters as far as zoning laws/permits and such. Any help would be appreciated. Thanks.
Julie2Oregon
# Posted: 6 Nov 2014 04:59pm
Some folks do great homemade systems. I'm hoping to use mine as a septic alternative with my solar/wind toilet system so I am looking to install the Light model of this: http://www.envirolet.com/greywater.html
Since it's just for me, the treatment capacity is more than enough for me and I would install it inside. I'm going to have a little "utility room" inside of my cabin. Hope this helps!
# Posted: 6 Nov 2014 05:11pm
https://www.thenaturalhome.com/greywater.html
downcard11
# Posted: 7 Nov 2014 11:11am
Thanks, folks
downcard11
# Posted: 7 Nov 2014 11:17am
Anyone have any experience with these?
Jim in NB
# Posted: 7 Nov 2014 11:21am
ANother source of grey water treatment info
http://www.kflapublichealth.ca/Files/Resources/Class_2_Systems___Greywater_Leaching_P its.pdf
Jim in NB
# Posted: 7 Nov 2014 11:23am
They work well - important to check to ensure that it meets local standards/regs. Obviously the more grease and similar products you put down your drain the more impact you will have your soil's ability to effectively treat the water - never mind increase contamination potential of ground water.
# Posted: 7 Nov 2014 05:06pm
Something un-mentioned here...
When installing Grey-Water system... keep it "down hill" from your water source and a minimum of 75' from your water source.
I just finished 4 days of excavator & backhoe work doing mine - what a job doing it on a hill side with some steep angles... Almost tipped a couple of times with the backhoe bringing in the 3/8's drainage gravel for the 100' of drain tile.
My system goes from cabin to tank which drains into 2 long runs of drainage pipe going downhill, 4' deep into the soil. The soil is sandy loam with about 6-10" good dark earth topsoil. Biggest hurdle was the big rocks (glacial deposits) and the darned tree roots.
OHHH... When your setup with GW, stick a NOTE above every sink that this is GREY WATER and no dumping stuff into the drain ! People will & do forget, especially guests. And do use GW Friendly products, detergents & stuff.
There are many methods & ways, depending on your layout, you could even use a greenhouse as your "bed" or create a small wetland with appropriate plants.
Humanure Handbook AND Wells & Septic Systems 2nd edition are good resources to get a hold of. Not BIG on info (how to) but good discussion & reference to ponder options.
Hope it helps. Steve
downcard11
# Posted: 8 Nov 2014 11:18pm
Hey thanks again everyone for the help.
redlandfd
# Posted: 12 Nov 2014 06:30pm
My 2 cents, I added a laundry room to my cabin, but the septic line was up hill from the washer. I built a shallow gravel pit under my deck and ran the drain pipe under the deck and to the pit (1dx3wx12L) it. The grey water runs in there overflows and is dispersed on the surface into a 20 x 20 bed/orchard of dwarf apple trees. Works great, trees are healthy and I haven't seen any gray water leave the orchard. Beyond that is a cow pasture full of poop, so if a few suds ever escaped...no biggie.
# Posted: 13 Nov 2014 06:09am
I run my shower /sink drains into 1 1/2 " PVC pipe--that that runs from the camp to a UNDER pile of pine logs and limbs left over from the cabin build 3 years ago. NEVER had any problem with smell etc. And the tree's near the bush pile look very healthy. This is about 50 feet from the side of camp.
I have a friend that has a hunting camp as well, his grey water runs into a buried 5 gallon bucket full of large stones. And the bucket has lots of hole drilled in it. He been using it for over 10 years like that. The top of the bucket is about a foot under normal ground.
Littlecooner
# Posted: 21 Nov 2014 07:48am
downcard11 - Go to the EPA website and download the following 400+ page manual. It was written in 1980 but is the current design manual which should answer any question you have "Design Manual: Onsite Wastewater Treatment and Disposal Systems (PDF) (409 pp, 9MB, About PDF)"
