bluefin
# Posted: 17 Aug 2014 02:59pm
I collect rainwater in two cisterns ( 1200 and 1500 gal plastic, above-ground tanks ) at a cabin we use year round. The water feeds the hose supply for dishes/showers/etc but we usually bring in drinking water. It also feeds a "flushing" Centrex NE2000 composting toilet. I dont want to use bleach as it will "kill" the composting action so want to use Hydrogen peroxide. \Does that make sense ? I cant find any resource to tell me how often/how much to use. Tanks are black but one does get some sun so want to keep water clean as much as possible.. Thanks for the advice..
# Posted: 17 Aug 2014 04:22pm
If you just want clean drinking water, consider the Berkey type water filters for drinking. They work slowly but remove most pathogens
bluefin
# Posted: 18 Aug 2014 01:57am
Actually...I dont need to get it that clean. I am fine carrying drinking water in. I just want clean cisterns and nice clean shower water..
I will check out those filters though...just in case.. thx
Bret
# Posted: 18 Aug 2014 07:29am
Check out Sawyer's Point One water filter. Better filtration, lower price, more versatile. Bret
SE Ohio
# Posted: 18 Aug 2014 12:49pm
Bluefin,
I understand that you are not trying to filter the water for drinking, sounds more like you want clean tanks? Not sure what you mean by composting action, though. Is this a process in the tank, or you are wetting down a compost bin and don't want to destroy process?
I would assume that peroxide would kill germs much as chlorine would. There is an old thread here about peroxide use.
If you are wanting to prevent growth in the tanks, blocking out light would help a lot. Adding either chlorine or peroxide would help keep growth in control. If you want water for compost pile, might consider a 55 gallon rain barrel or two untreated.
SE Ohio
# Posted: 18 Aug 2014 12:57pm
Here's an old thread with water treatment instructions:
http://www.small-cabin.com/forum/3_3546_0.html#msg51969
bluefin
# Posted: 19 Aug 2014 12:24am
Thank you...sorry if I wasn't clear... The tanks are dark so as to inhibit growth however, I was thinking I should add some Hydr Perox to clean any buildup/algae that I might not see. If I use chlorine, the water that flushes from my composting toilet into the holding tank would have chlorine and would inhibit/stop the composting action in that tank as the chlorine would kill the bacteria. I dont think the Hydr Perox would do that but want to confirm that and understand how much should I add to the tanks and how often it should be added. I dont think I need a filter system as the water looks pretty good now and is only for showers and dishes.. Thanks for taking the time so far to help out..
# Posted: 19 Aug 2014 05:12pm
Can you put the 1200 gallon tank directly to your toilet use only (un treated) leaving the 1500 gallon tank for chlorine treated water to the rest of your cabin hold(house hold) needs?
papawawesome
# Posted: 21 Aug 2014 05:57am
That seems like an easy logical solution to the problem.
rugercpl
# Posted: 23 Aug 2014 11:21am
I use pool shock. I guess that's the same as chlorine? Sodium Hypochlorite I believe? In my 200 gallon cistern I just sprinkle a couple of teaspoons when it's newly filled. It's cheap and lasts forever. I don't drink it but I could if I had to. I shower with it, toilet, and wash dishes. It has a slight smell of chlorine like municipal water does. It probably conflicts with the beneficial bacteria of my gray and black water tank but it's not a permanent septic system so I worry less.
Lynn
# Posted: 10 Apr 2024 12:56pm
Bluefin, I have a very, very similar situation. Did you ever get an answer that helped you? If so, will you share that answer?
