# Posted: 7 Jul 2014 09:25am - Edited by: groingo
I have two killawatt meters both show 120 volts at 2.87 amps producing 228 watts, but every website calculator says it should be 344 watts at 2.87 amps at 120... which is right? I contacted P3 and they told me I needed to use the VA (volt amp) feaure which now shows it is pulling 360 watt... .ok? Sure wish this charger had some sort of meter so I could see what it was putting out instead of an idiot light.
old243
# Posted: 8 Jul 2014 02:34pm
watts =volts x amps. is the formula 120 voltsx 2.87 amps = 344 watts
for a given load ,if the voltage increases, the amperage decreases. Or vice versa if the voltage decreases. old243
# Posted: 8 Jul 2014 04:01pm - Edited by: razmichael
Suspect the confusion is because your voltage is AC not DC. See tables for examples with single and 3 phase AC. With single phase AC you need to multiply by a power factor which may be around .8.
