# Posted: 17 May 2014 02:37pm - Edited by: groingo
Reply Quote
Checking my charger and was curious how long it should take to add 5.00 amps to a 12 volt battery at 10 amp charge rate? I came up with 1.002975 hours. Next step is to verify and if works it could mean a much smaller solar system may fill the bill.
Flying Wrench
# Posted: 18 May 2014 10:05pm
Reply Quote
What is the capacity of your battery? Also, keep in mind that charging your battery won't be 100% efficient.
# Posted: 18 May 2014 11:03pm - Edited by: groingo
Reply Quote
Interstate battery was where I got the formula, tomorrow with a new set of batteries I will begin to verify if what they say is correct, my number also included a 15% variance on the high side....we'll see.
# Posted: 19 May 2014 11:46am
Reply Quote
Looking forward to your results. I would have thought around 45 minutes... figuring the charging process to be 35% inefficient.
# Posted: 19 May 2014 12:55pm
Reply Quote
Well, I decided to go with the 235 amp hour Trojan batteries which will be here in a couple of days, gives me time get things ready. As far as charge requirements that's also why I decided to go with the Trojans, just a better all round battery than the less expensive Empires, soon we shall see what is really what once and for all.
# Posted: 19 May 2014 01:23pm
Reply Quote
cool. How many batteries?
# Posted: 19 May 2014 02:47pm
Reply Quote
Just two 6 volt 235 ah.
# Posted: 19 May 2014 07:46pm
Reply Quote
Run some tests using a good hydrometer to determine charge state before being charged and to tell when the battery is really full. Better than voltage readings. Keep a log of the cells over time. Helps find problems.
# Posted: 19 May 2014 09:55pm - Edited by: groingo
Reply Quote
Funny you brought that up, Interstate suggested the same thing so I got one yesterday. Crown battery also wants information when I get it, they agree with the numbers so this might get interesting, it will sure help simplify things to be sure.
# Posted: 19 May 2014 10:34pm
Reply Quote
I am a big believer in logging data. I have gone as far as photographing the cells when new and more or less yearly after that.
Does your hydrometer have a thermometer built in? Temperature correction is important if the battery temperature varies much seasonally. I have an old one with a thermometer I got at NAPA. But there's another I actually like better as the float is easier to read. I use a glass lab thermometer with it.
