Small Cabin Forum / Off-Grid Living / charge controler and powerbox 800 setup help
Smashems
# Posted: 3 Apr 2010 02:54pm
The only answer i found was related to the powerbox 1200 and was suggested to simply use the screw caps on the back and was also advised not to use the 12v DC plug to charge the powerbox.
This is were i'm getting confused, is the 1200 DC plug regulated and the 800 DC plug is not? the 800 DC plug is made for charging in the car via the cars 12volt charge controller.
I have 2 x 15watt panels, 1x 7amp controller and a powerbox 800.
Could i simply plug my controller in the DC plug and let it be? the panel are made to be simply left plugged in all the time even when the power box is in use, since I'm not charging via the AC right?
Moontreeranch
# Posted: 5 Apr 2010 06:21pm
not sure about some of the specs on the power box 800
here is a site for some answers on the 1200
http://answers.canadiantire.ca/answers/9045/product/0111815P/questions.htm
My idea is that your charge controller should limit any overcharge condition for the 800. SLA batteries like charge voltages of about 14 to 14.5 volts..this is what your charge controller should output..it it has a selection range check to make sure it is compatible with the SLA in the power box.
FLAs can take higher charge voltages
Pylonman
# Posted: 8 Jun 2010 05:48pm
Your on the right track. I have two PowerBox 1200's. I tied and taped the wires from my DIY 63 Watt panel to a $39.00 Sunforce charge controller. Then, I connected the leads from the charge controller to the red/black screw on terminals. In 2 days the PowerBox was charged. The charge controller prevents the batteries from overcharging.
Sometimes, when both PowerBoxs are low, I hook up a spare 12 Volt deep cycle trolling battery to the other box (not being solar charged). If I wait 6 - 8 hours (or if I pop into town from something) the second PowerBox will get some juice. It then is top up later solar of gas AC generator.
# Posted: 11 Jun 2010 02:03pm
For what I know, the power 800 have a built in controler.
hinterland
# Posted: 14 Jun 2010 05:17pm
Yes, the Powerbox 800 has a built in controller and inverter. It's a plug and leave it on the AC, but have not tried it on solar.
